base stereo's speakers
Old 11/4/06 | 12:09 PM
nbk13nw's Avatar
I did the entire car... trunk, floor, quarter panels on front and rear, inside the front doors (Outer skin) and inside door panels that the speaker mounts to. Firewall, tranny tunnel... everything I could get at. The only thing I did not mat was the roof. One thing with FatMat... I also used a spray adhesive on the vertical panels and the ones that are upside down. Just in case things wanted to drop.
I used FatMat since I found it on eBay for under $100.00 for 150 SQ FT.
As for the doors, If not doing the entire panels outside and inside skins, then at least a 10"x10" or larger directly behind the door speakers on the outside door panel.
Old 11/4/06 | 12:17 PM
mc_mstng's Avatar
Is 150 sq. ft. pretty close to what you needed?
Old 11/4/06 | 12:26 PM
nbk13nw's Avatar
Yup, had a little bit left over too. Here is a link for an eBayer.
http://cgi.ebay.com/100-fatmat-autom...QQcmdZViewItem
Old 11/4/06 | 12:27 PM
nbk13nw's Avatar
Most likely 100 sqft would be enough.. I may have over done some areas, especially in the trunk. I even applied it under the rear deck. And two layers across the entire trunk. Got rid of most of the drone noise inside the car.
duppycat
2/16/19 08:36 AM
CNFLCTD
GT350
8/4/17 07:08 AM
Fedupdave42169
10/23/15 09:58 AM
9/30/15 07:02 PM
exgto
2012-2013 BOSS 302
9/28/15 07:39 PM
Quick Reply: base stereo's speakers
