Aux button radio [Mustang 2005 V6 Base]
Old May 16, 2021 | 11:24 AM
Jos's Avatar
Jos
Hello,
I own a "Mustang 2005 V6 Base". On my radio there is an AUX button but this button doesn't work. I think I have a Shaker 500/1000 (Picture radio: https://postimg.cc/GTmYskkL).
How can the AUX button work?
Is this a possible solution?
Amazon Amazon
Or any better solution?
Best regards,
Jos
Old May 21, 2021 | 12:20 PM
Dark Drop Top's Avatar
I didn't know anybody made a unit that plugs into the radio wire plug.
I've been using a cheap bluetooth unit that plugs into the lighter/power outlet.You set your radio to the same station that the bluetooth unit is set on.Then it gets bluetooth signal from your phone and sends it to your radio
Old May 22, 2021 | 11:41 AM
houtex's Avatar
Yeah, in our cars the 'Aux' is just there, doesn't do anything. There's supposed to be a way to make it work, but...eh, easier to get a new head unit, or the bluetooth/transmitter thing.
Old May 22, 2021 | 12:36 PM
I just finished going through the owners manual again and I can't find any indication of how you're supposed to hook something up to use the aux.All it says about it is that if you push the aux button w/o something hooked up to use it,the display will say "no aux source",or something like that
Maybe the unit you linked to is how it's meant to be used
Old May 23, 2021 | 07:11 AM
NC14GT's Avatar
The AUX button on my '07 works with the satellite radio. It gives you new pre-set options and new channels. Several levels. I've used it since day 1.
Old May 23, 2021 | 12:24 PM
Jos's Avatar
Jos
Thanks, I use these thing for a couple of months but the sound is not the same like it is with for example the CD-player. But I ordered the AUX thing from Amazon and in the next weeks I will check it out if I can connect that to my radio. I will let you know. Thanks for reply.
Old May 23, 2021 | 03:36 PM
Yeah,I forgot to mention that the sound quality is not very good.I dunno if it's because mine is a cheapo unit,or if that's the nature of the beast with the radio type units.I really wish my disc changer worked,I still have hundreds of cd's but can't use them in the stang
Old May 26, 2021 | 03:05 PM
Jaryd21's Avatar
My 08 V6 is the same way but if you plug something into the aux port it works, just as yours not the same quality.
Old May 26, 2021 | 03:55 PM
You mean yours actually has a port to plug something into?I can't find anything on mine.I also have a shaker 500 head unit that a friend gave me,and I can't find anything on it either
Old May 26, 2021 | 07:14 PM
Jaryd21's Avatar
Check the glove box
Old May 26, 2021 | 08:25 PM
The port is in the glove box???This I gotta see
I just locked up the garage,and it just started raining hard,so I'll check it out tomorrow
Old May 27, 2021 | 04:49 AM
Jaryd21's Avatar
No no no I am sorry, I meant the center console/arm rest. My bad there should be a power outlet and a aux port.
Old May 27, 2021 | 02:14 PM
I thoroughly searched all in the console to no avail.Only found a power port/lighter.I even went so far as to pop off the square cover at the left front top in the console and looked down in there with a flashlight
I just came across an ancient post on another forum that mentioned it being in the glove box.I'm gonna take a good look in there with a flashlight
Old May 27, 2021 | 03:26 PM
Still no sign of a port anywhere
Old May 27, 2021 | 03:41 PM
Right after my last post I googled for the location,and found out they didn't put the port in until the 07 or 08 models.Until then,the aux button did nothing unless your car had optional satellite radio
Old May 27, 2021 | 08:56 PM
Jaryd21's Avatar
That clears it up, my 07 gt has a aftermarket radio with bluetooth so I never looked anywhere for a aux. My p8 has it in the center console. Didnt even think that they never put one in yours. Sorry you have a dead aux button.
JOEGTS
05-09 Interior and Audio Mods
17
Mar 7, 2013 10:27 AM
hihosilver
Sep 15, 2010 03:53 PM
ultimix
14
Jan 10, 2007 02:04 PM
06TUNGVERTGT
Nov 9, 2005 03:02 PM
GhostTX
May 13, 2005 09:14 AM
