Auto-dimming rearview mirror
Originally posted by Martimus+March 13, 2005, 8:50 AM--><div class='quotetop'>QUOTE(Martimus @ March 13, 2005, 8:50 AM)</div><div class='quotemain'><!--QuoteBegin-HOTLAP@March 13, 2005, 12:36 AM
Peet - just finished successfully installing my Auto dimming rear view mirror with compass and Home Link. Was very easy and ended up connecting all 3 wires. the outside solid black wire was for the always "hot" lead (I used the power mirror fuse) and the black w/white stripe was for the "switched" power and I ran it to the wiper fuse. Center black wire went to frame ground under the map light housing. Works great and thanks again for the "Subaru" lead - must have saved me $100 - $150 for the same mirror!! :worship: :worship:
Easy install down the passenger side "A" pillar to the fuse box in the passenger kick panel.
Neither set of instructions (Ford or Subaru) was very clear as to what the solid black "always hot" lead was for.....all I can figure is it may be for the Compass memory or something? No mention of connecting it to the reverse light circuit - so I doubt it has anything to do with the "reverse cancellation feature" cancelling the auto dim feature while in reverse....my LS had this - but can't say that I miss it much - as it would only apply while dark out/in reverse if another cars lights are hitting your mirror.....I did test the black/white wire and it operates all the mirrors features - compass, auto dim and Home Link......
1. The center black lead is the ground (the Ford harness has a circular lug installed on that lug from the factory)
2. The black lead with white stripe (connectors tinned copper) connects to a switched +12v source and provides power to the compass and undim functions
3. The other black lead (connectors tinned silver) connects to an always on +12v source and provides power to the homelink circuitry in the mirror.
[/b][/quote]
Martimus - interesting findings - mine were different - the Subaru mirror is identical to the Ford unit (both made by the same company) only I found the blackw/white wire powers all the mirror functions (inc. Home Link) as all functions worked w/o the (non ground) solid black wire being connected......and I do like the idea that with the ignition off my Home Link is disabled as well.....that's why I figured the solid black + wire must be for the compass memory or something since it does need an always on power source and didn't appear to control anything obvious.....I would like to have clearer instructions on what each wire does though as both sets of instructions were vague......please post any additional findings...thx!
1 Post
I hear ya... I first tried installing a locally purchased Subaru homelink miror (officially for a WRX) but ran into two problems (well actually three). First the mirror was HUGE compared to this Ford homelink mirror. Second the mirror was bad (I could not get it to power up under ANY circumstance). And third the local Subaru dealer was run by a bunch of yahoo's (I asked for a replacement and they said it was on back-order and they didn't know when they'd get any. I then asked for assistance trying to troubleshoot the mirror and they said they couldn't help. I finally asked for a refund which they got around to sending me two WEEKS after receiving the bad part).
In my testing of the Ford mirror I first installed just the ground wire and the black/white +12v lead. What I found was that the green undim light came on and the compass started working. When I tried resetting homelink it did absolutely nothing. I contacted homelink and they suggested that it might be a wiring problem. I then tried connecting just the black +12v lead and shazam the homelink would now reset (I got the red blinking light when I pressed both the homelink 1 and 3 buttons for 20 seconds). At this point homelink was now worked but my compass and undim didn't work. I then tried splicing the two +12v leads together and all functions now worked.
My final change was to re-crimp female connectors (I found right angle connectors at Auto Zone) to each +12v lead and connected the black/white to a +12v switched source and the black-only to an always-on +12v source. At this point everything works and my homelink is available with or without the ignition being on. At this point Kevin (05stangkc BTW Thanks again Kevin!!!!!) sent me the proper manuals and I verified that this was consistent with Ford's recommended installation procedure (manually by the way was speciflcally for Ford p/n 4L3Z-17700-AA which is the Ford homelink mirror with compass).
1 Post
Originally posted by HOTLAP+March 13, 2005, 10:41 AM--><div class='quotetop'>QUOTE(HOTLAP @ March 13, 2005, 10:41 AM)</div><div class='quotemain'><!--QuoteBegin-Martimus@March 13, 2005, 11:29 AM
[/b][/quote]
Yea they're definitely different mirors. Mine is configured just like yours (homelink 1, 2, and 3, auto dim power button, and compass power button) but their are definitely different variations based on my experiences with the Subaru and now the Ford mirrors.
In Peet's post (#16) the mirror in the link says it's only for the Legacy & Outback. Maybe that's the only one that's identical to the Ford Mustang version. Maybe the WRX version is different.
1 Post
It ended up costing me more but my homelink mirror is now installed, working like a charm, and my Mineral Gray doesn't have to deal with me monkeying around in the passenger side fuse box anymore. Somehow I suspect the car deserves a couple of nanners for putting up with me the last few days...
Originally posted by Martimus+March 14, 2005, 12:01 AM--><div class='quotetop'>QUOTE(Martimus @ March 14, 2005, 12:01 AM)</div><div class='quotemain'><!--QuoteBegin-StangNut@March 13, 2005, 8:54 PM
[/b][/quote]
Martin - your stang is indeed a lucky steed to have an ownerlike you I think perhaps we do have the same mirror and the WRX mirror must be diferent - mine came with the Legacy/Outbck instructions.....all is working well and thanks for your input!!!
So what is the low cost source to get the mirrors with homelink, compass AND temp? I would be willing to do away with homelink (for now anyway) just for compass and temp.
Roamer - here is the link that Peet included above: http://secure.cartsvr.net/catalogs/catalog...&showprevnext=1
Well that didn't work - I never did figure out how to copy a link and make it work - but check out Peet's link above - they may have the temp model as well.
Hi folks. Sorry been away.
The mirror itself is physically identical to the ford one (that is Subaru's) with one big difference. the extra wire on the Subaru mirror is the disable trigger not a constant on. It is designed to hook up to the reverse lights - this way when you put it in reverse and trigger this line, you turn off dimming. The thinking is you are in a garage and need to see backing out.
Hope that helps!
P
Hope that helps!
P
1 Post
Originally posted by HOTLAP+March 14, 2005, 12:15 AM--><div class='quotetop'>QUOTE(HOTLAP @ March 14, 2005, 12:15 AM)</div><div class='quotemain'>
Very possible indeed... I got lucky (well sort of) when I found the Subaru WRX homelink mirror. I had called four dealers and this was the ONLY Subaru homelink mirror in all of Phoenix. As it turned out the mirror itself was about 30% bigger than the Ford mirror, the wiring harness had three conductors, one jumper, and a gray and white plug. Oh well...
[/b][/quote]
My stang is simply tolerant of a hack like me. But thanks nonetheless for the kind words!
If I buy the mirror Peet posted, do you think my local Subaru dealership would install it? Or even my Ford dealership?
Just how hard is it to install? If it was reasonable to have one of the dealerships install it, I’d rather go that way then mess around with wires.
The Mazda6 version of the auto-dimming Homelink mirror is exactly like the Ford mirror. You can get the version with the compass for $225 here:
http://www.mazdastuff.com/product.cfm?ProductID=1987
1 Post
In terms of Ford I would suspect they wouldn't want to install a non-Ford mirror for liability reasons. Now a third alternative might be to contact a local stereo/accessories store. They might be more willing to do the install for you.
Originally posted by StangNut@March 15, 2005, 7:52 PM
I think I'd rather buy from Subaru for $192.
Personally, I'd rather give my money to Ford (via Mazda) rather than to GM (via Subaru).
Originally posted by TomServo92+March 15, 2005, 10:32 PM--><div class='quotetop'>QUOTE(TomServo92 @ March 15, 2005, 10:32 PM)</div><div class='quotemain'><!--QuoteBegin-StangNut@March 15, 2005, 7:52 PM
[/b][/quote]
How do you figure the Subaru mirror is huge in comparison to Ford's? From every indication it's the exact same unit - albeit with different logic (ford has power after ignition off, subaru has dim defeat on reverse). Yes the unit is bigger than stock - thankfully! (LOL that stock mirror was almost worthless).
That having been said, the ford mirror itself is not plug and play. I have the ford manuals and they REQUIRE that you wire the mirror using a fuse power splitter. No different than what you'd have to do with the other branded units. The difference may be that the ford mirror comes with a longer pigtail so you don't have to add wire.
Now then, looking at the mazda pic and having lived with the Subbie mirror now for almost a month - I can say they are the same thing. Not sure how the size thing came into play - unless somehow you bought a different subaru unit than the one I did - always a possibility.
P
P
P
1 Post
Originally posted by TomServo92+March 16, 2005, 6:09 AM--><div class='quotetop'>QUOTE(TomServo92 @ March 16, 2005, 6:09 AM)</div><div class='quotemain'><!--QuoteBegin-peet@March 16, 2005, 1:32 AM
P
P
[/b][/quote]
The Subaru mirror I was able to get my hands on WAS bigger. It was, however, a mirror intended for a WRX rather than the Outback mirror that Peet had been working with. As I've never seen the Outback mirror I can't speak for its size but I suspect it very well may have been a different sized mirror. Installing the Ford mirror was no more difficult than installing the Subaru mirror.
When I attempted to install the WRX mirror I sliced the 6-inch long Subaru wiring harness in half, soldered longer wires onto it, and ran the newly extended harness down to the fuse box. I used fuse take-off adapters to allow me to piggy-back the connections onto existing fuses (I had purchased an "Add-a-line tap" but ended up not using it).
When I installed the Ford mirror I simply ran the factory harness down to the fuse box and connected the hot leads using the same fuse take-off adapters.
The one concern I had, and still have, with using either the take-off adapters or the add-a-line tap is that both seemed to prevent me from easily replacing the cover on the fuse box. As such I simply put the cover in a safe place and replaced the cover on the kick panel.
#40
Well I was going to have it added at dealer, but they wanted like 500.00 total installed. I said that's ok. I added bluetooth cell kit instead and wheel locks, and ashtray kit. 500 for a mirror with some gadgets, you must be crazy.
