Aeroforce interceptor gauge
Old Sep 24, 2012 | 09:46 PM
Victorfriessen's Avatar
I just installed a Aeroforce Interceptor gauge and Im wondering if anybody know the normal temperature range from transmission,head,exhaust,coolant,ait and what the timing advance should be at the most?
Old Sep 29, 2012 | 10:14 PM
AlloyGT's Avatar
My transmission runs about 170, but I have a deep trans pan (4 extra quarts) and a 3200 stall converter. Unfortunately, I got the gauges after the pan and torque converter, so I don't know what it would run stock. Coolant and head always read the same. 195 in normal driving, up to 203 with the A/C on. IAT may depend on which CAI you have. I have a JLT2 with an AEM dry filter, and my IATs run about anywhere from 10-20 above ambient when cruising at 50 mph. IAT will go up by 30 degrees or more while stopped in traffic, but they drop fairly quickly once you're moving. I don't monitor exhaust, but when playing around with the gauges when I first got them, I think the cats were like 1400-1500 degrees. I can't remember what I saw for timing. It was another parameter that I played with, but didn't end up monitoring.
Old Oct 2, 2012 | 11:06 PM
Thanx for the reply,look pretty much like mine,only that my trans runs at 180 usually,and I have a 3000 torque converter from TCI,what torque converter do you have?
Old Oct 2, 2012 | 11:55 PM
AlloyGT's Avatar
PI multi-disc, 3200 stall. Maybe that means the deep pan really does help with temps.
Old Oct 3, 2012 | 10:30 AM
I bet it does,how much are those converters?
Old Oct 6, 2012 | 12:16 PM
AlloyGT's Avatar
They run about $1000. I got mine used.
Old Oct 7, 2012 | 09:29 AM
How much are the deep pans?
Old Oct 8, 2012 | 04:11 AM
Scott2's Avatar
I have a Performance Automatic Deep Pan and Dipstick in my car.
http://www.americanmuscle.com/perfor...span-0510.html
Here is a picture of the pan:
Old Oct 8, 2012 | 01:51 PM
Have you had problem with bumps since the pan looks really big
Old Oct 8, 2012 | 06:13 PM
Scott2's Avatar
No issue, this picture is a little better. The pan does not hang down below the exhaust system:
Old Oct 9, 2012 | 07:45 AM
Nice suspension work,Im for sure getting a deep pan ,thanx for the pics
K.A.I.N
Sep 25, 2015 03:27 PM
Kefka21
Aug 28, 2015 03:11 PM
