whats the deal with these
http://store.cal-mustang.com/cm_able/showd...ATID=25&CM_SA=0
on the bottom it says gauges not included???
Would i be getting ripped off if i bought this
I couple things you should know before buying this. The price is just for the pod, I personally don't think its a bad price; it looks a lot better then the other dash pods I've seen however there is the issue of having to put a hole in the dash to install it.
1) You will have to drill a hole in the dash to wire the gauges.
2) I have had this on order since Feb. and it still on back order.
