Well I finally gained the confidence to do it...
Looks good. Did you clear them at all? I would have personally put a few coats on the back-up section as well, but that's just me. I'd also ask if its going to be an issue with the police in Florida, but by the looks of your license plate, it won't.
On the subject of the law...I looked up the Georgia law(my car is registered in FL with my parents residence) and all it says is that the lights need to have reflective properties, be seen from 500 feet away during the day and brake lights be seen from 300 feet away at night. But I do have a blue-bar sticker (family of law enforcement) so hopefully that will keep them away. ha
For safety.....The light shines through almost just as well with none. You can't tell there's anything on the light. As for looks.....I have a theme for my car and blacked out taillights added to it. My fact and opinion though....
I would not say they're even remotely as transparent as stockers. I've used VHT on the gf's GT -- 3 layers -- and they're so dark I refuse to do her 3rd brake light. Same with some other cars I've done.
But I do like blacked out tails. Well done.
Thanks man. I'm going to take a picture tonight and post it to show the transparency. They're very visible.
In Texas you need to have red reflection in your tail lights, so I just threw on some smoked vinyl and called it a day. I used VHT for my previous car and it came out well, though I didn't clear it. One thing first-time Nightshade users don't realize is it WILL darken up as it dries.
Send me one of those blue line stickers! I've been trying to get one for a while.
If they are blind enough not to see a whole complete car going down the road how do you expect them to see lights?
I also need a new blackout panel. Mine is kinda dull and faded and doesnt fit right. Where di you get yours??
I got my blackout from ....................
http://www.americanmuscle.com/blacko...l-install.html
The tailight bezels..........................
http://www.v6mustangstuff.com/05taillight_trim.htm
If you spray in a sweeping motion you will have more controll of you spray. I like to make 2inch sweeping paths.
Make sure each sweep is smooth and clear. If you apply the vht smoothly and clearly you lights will be brighter. Once you have swept the complete light let the light dry. If you want the light darker sweep the whole light again but be careful vht can get dark real fast. Spray the clear on the same way as the vht by using the sweeping motion. 3 coats of clear minimum I like 5 layers. That way you can color sand the light until all the blemishes are gone and the light is completely smooth. Now buff the light using plenty of buffing solution and make sure the light doesn't get hot while buffing or the lens will warp. Hope that helps you.
