VINYL REAR BLACKOUT ?
Old Aug 23, 2005 | 03:24 PM
PHATTZZ STANG's Avatar
I just got mine is there any problem with these any sugesstion to make install easier
Old Aug 24, 2005 | 04:07 AM
silverado's Avatar
Forget vinyl blackouts. I think they look cheap. I ordered the 3dcarbon blackout PANEL. Had it painted glossy black and clearcoated
Old Aug 24, 2005 | 04:11 AM
Blk'05's Avatar
Yeah...well hes already got this one soooo. Anyone have anything helpful to post?
Old Aug 24, 2005 | 05:20 AM
porkster's Avatar
I wish someone had told me the "easy" way. What I learned from putting mine on...
Mix some dish soap in a squirt bottle with water. Wet the surface of the car, and the back of the vinyl. It will not stick at first. I tried doing it dry and it was so sticky, once it touched the paint, there was no moving it! Bubbles were stuck. I peeled it off, got it wet, and that made it soooo much easier. You can slide it around, get it positioned just right, then start squeegie-ing.
Start at the center, around the fake gas cap. Lay it down, trying to push out as much air as possible. Squeegie as you go. Oh, and use a soft squeegie, and keep the outside surface wet as well, to avoid scratching it. As it drys, it will stick really well. Keep squeegie-ing and pressing. It will eventually all dry out and stick, even along the edges. I was worried about the edges where it just barely wrapped around the edge of the trunk, but it did stick. Keep pressing it.
Hope that helps.
Old Aug 24, 2005 | 08:18 PM
Cam07's Avatar
I've been thinking about getting a vinyl blackout panel. Does anyone have any pictures of one on your car. silverado, any pictures of your blackout from 3D Carbon?
Old Aug 24, 2005 | 08:54 PM
TN615's Avatar
Get a life.
Old Aug 24, 2005 | 09:36 PM
X13's Avatar
X13
Did you need to use a heat gun to get the corners to wrap around the lip? IMHO the vinyl or painted panel looks better than any prefab panel I've seen so far. The prefabs may be simple to install but I don't care for the sunken gas cap look.
Old Aug 25, 2005 | 05:23 AM
porkster's Avatar
No, I didnt use any heat. I just kept pressing on it as it dryed, and it eventually stuck nice. The next day I realized I had parked with my rear facing East, and it got nicely heated up in the sun (Florida here), and that did help with the itty bitty air bubbles.
You can see my rear here:
http://chickenchaps.myphotoalbum.com/view_...les&id=RearLime
I dont understand what you mean about the sunken gas cap look.??
Old Aug 25, 2005 | 09:06 AM
mustp51's Avatar
I believe he is talking about this look, on the one from Silverhorse Racing..
Old Aug 25, 2005 | 09:11 AM
mustp51's Avatar
Here is a pic of the Lexan one from GTS
Old Aug 25, 2005 | 10:31 AM
Kluski's Avatar
No cheapness about it. I have had several people think mine was painted.
As for the corners, I just kept rubbing them down. It took a little while, but it all stuck just fine.
No heat gun used. Just the saop/water mixture and some rubbing.
Old Aug 25, 2005 | 07:50 PM
X13's Avatar
X13
Yes thanks Jeff thats exactly what I was talking about.
Chris, I've seen your car pictures in the past and it was the main reason I decided to go with the blackout panel on my car. Your car looks great. Nice job...
Old Aug 26, 2005 | 10:37 AM
Kluski's Avatar
I am glad I could influence you to spend your money. Now I just need to influence you to send money to me so I can buy more mods.
Old Aug 26, 2005 | 10:48 AM
ravenblack67's Avatar
I have had mine for 8 months. I love it. Easy to apply and easy to remove. Cheaper than plastic and paint.
Old Aug 26, 2005 | 03:51 PM
HastaLaVista's Avatar
Where did you get that? How much?
Old Aug 26, 2005 | 07:58 PM
Cam07's Avatar
I would like to know where you got it also. It looks great!!!
Old Aug 29, 2005 | 10:28 AM
Kluski's Avatar
I got it on ebay. Not sure if the guy still sells them, but it was posted on here about his auctions. I think a lot of people got one from him. It was around $25-30.
I put mine on back in April I think.
Old Aug 29, 2005 | 10:37 AM
Got a name?
Old Aug 29, 2005 | 11:43 AM
porkster's Avatar
I am not sure where mine came from as it was a birthday present, but...
do a search in Ebay for "Mustang blackout", you will see some.
or try this link:
http://cgi.ebay.com/ebaymotors/2005-MUSTAN...sspagenameZWDVW
Old Aug 31, 2005 | 10:15 AM
Kluski's Avatar
That look like a different guy. I can't remember the one I bought it from. If you search my post about blackout panels, I am sure I mentioned it somewhere before.
The guy had a yellow pony on his auctions. He said he might use my car since I sent nice pictures when I did mine originally.
