Tire Size Question...
I posted a thread about AFS Black Bullitt wheels a while back and think I'm gonna pull the trigger now...
They have 18x9 fronts and 18x10.5 rears available which is what I'd like to purchase and they have them available with Goodyear F1 Supercar tires as well.
Here's my question. The tires size they come with are as follows:
Front: 255/45/18
Rear: 285/40/18
Can someone please explain to me why the tire sidewall height differs from front to rear?
My goal is to have some meaty looking tires for a more aggressive muscle car approach. Are these the tire dimensions I'm looking for? Or what would you guys recommend?
Also how will this affect my speedometer and mileage readings and how can I adjust that in order for them to remain constant to the current reading?
Front: 255/45/18
Rear: 285/40/18
These sizes of tires most closely resemble the stock tire diameter, if the stock tire is a 235/50/18. Check out the link below its a tire size calculator you plug in tire size and it gives info such as diamater and sidewall actual height.
To see the numbers for your existing tires plug in those numbers and compare with what you want
http://www.discounttire.com/dtcs/infoTireMath.dos
255 is width across tire sideall to sidewall in mm
45 is tire side wall height as a ratio to width, height would be 45% of 255 mm=114.75mm
18 of course is wheel size
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
From what I understand having the smaller sidewall height in the rear is to keep the dimensions as close to possible to stock.
Would I have to re-calibrate my speedometer after the purchase in order not to screw up my mileage?
Depends. My goal was to keep the overall diameter and therfore revolutions per mile similar + or - a mph or 2, but since I have an XCal 2 Tuner I had Brent include the corrected tire size in my tune, or from what I understand it can be user set in the Xcal 2 under user parameters? or something like that. A 285/40/18 is very close to a 235/50/18 that came on my car though.
Thanks for the compliment, it means alot when someone validates what you've done. Sometimes I just hope I haven't done too much, but I look at it and right now it fits me perfectly. All I want now is more power.
I look at your car, and it pretty much expresses everything I'd want out of mine as well.
Very nicely done, the compliments are well deserved.
I went with 18x9 18x10
255/45/18
285/40/18
F1 Supercars
no speedo calibration required.
Looks good I think.
Roush rear springs coming out and pro kit/Dspecs going in shortly
![](http://www.06gt.com/coppermine/albums/wheels/CTR08.JPG)
![](http://www.06gt.com/coppermine/albums/wheels/CTR20.JPG)
![](http://www.06gt.com/coppermine/albums/wheels/CTR22.JPG)
![](http://www.06gt.com/coppermine/albums/wheels/CTR26.JPG)
![](http://www.06gt.com/coppermine/albums/wheels/CTR28.JPG)
255/45/18
285/40/18
F1 Supercars
Looks good I think.
Those are some nice pictures, thanks for sharing!
I just got back home from purchasing my wheels and tires. I too ended up with Supercars in the exact same sizing as yourself.
Here's another question. After a wheel & tire change, is an alignment required? Or can we just go ahead and mount them without any issues?
Thanks!
Thanks!
No issue with alignment change.
Just going to be a pain in the butt getting alignment heads on the wheels without scratching them when I do align it after suspension mods later this month. Darn rim flange protectors on the tires hug the lip of the wheel.
Thanks!
Thanks!
Please excuse the phone pictures, there will be good quality pictures to come, but here's a little something to give you an idea of what I went with.
Thank you all for your help and advice.
![](http://i22.photobucket.com/albums/b350/XxDevilR6xX/Mustang%20GT/BullittWheels1.jpg)
![](http://i22.photobucket.com/albums/b350/XxDevilR6xX/Mustang%20GT/BullittWheels2.jpg)
![](http://i22.photobucket.com/albums/b350/XxDevilR6xX/Mustang%20GT/BullittWheels3.jpg)
Id love to toss a 305 or 315 on there some day. Its all about matching tires tho on the fronts to back.
Ill look at the availability on 305's when im sober.
JonathonK
7/27/15 07:35 PM
