Street Scene Front Fascia
Old Sep 22, 2005 | 06:29 PM
scotts05custom's Avatar
I am pretty sure that I know the answer to this question, but does anybody know if the GT front fascia will fit on the V6.
You see, I currently have a GT grille in my stock V6 bumper. From what I read, the only difference from the Street Scene fascias, is that the GT holds the GT grille, and the V6 holds the V6 grille. So therefore, if I buy the GT fascia, and put my GT grille in it, it would still correctly bolt on my V6, correct?
I think this is right, because people are buying stock GT bumpers and putting them on their V6's, therefore both bumpers having the same bolt on points.
Just wanted to make sure before I order, any help?
Thanks.
Old Sep 22, 2005 | 11:53 PM
Shaun81's Avatar
A stock GT bumper mounts the same as the stock V6 bumper, so I guess the SS would work the same but to be safe would be best to contact them and make sure.
Old Sep 24, 2005 | 08:28 AM
hippiehead025's Avatar
did you get an actual GT grille for your V6? or did you get the GT conversion grille for your V6? If you got the conversion grille, it wont work. The mounting points are different in the actual GT grille, and i was also told its wider. so if you have the conversion grille, it will be smallerthan the opening. But the bumper coveri tself mounts same way for v6 or GT. - Roger
Old Sep 24, 2005 | 11:30 AM
Mustang Mike 05's Avatar
If you have the factory GT grille shell, then order the factory GT Front Facia from Street Scene. The only other diffrence is that on the GT, there is a tray on the bottom that feeds air to the radiator. You dont have that on the V6 but everything else should mount up the same. You might want to pre-mount it prior to painting just to make sure..
Old Sep 24, 2005 | 05:25 PM
Alright, thanks I got the answers I needed.
I do have a factory GT grille in my factory V6 front fascia now.
Old Sep 28, 2005 | 02:07 AM
Iwanta05's Avatar
street scenes is the best body kit out there
Old Sep 28, 2005 | 05:25 PM
I have just decided to wait and get my Street Scene Body Kit in the spring.
1) Dont want the weather it in the winter
2) I wanna see there generation 2 body kit
seaclam
Sep 25, 2015 01:29 PM
Evil_Capri
Sep 25, 2015 12:56 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
