Sequential turn signal mod!
Old Apr 23, 2005 | 03:13 AM
JHL981's Avatar
Smile
Im pissed, so I bought a turn signal sequencer kit off e-bay. I cant afford the plug n play ones. So I bought the one that requires a few crimps and such since I got it for a good price at $48.00 with best offer. Well, FIRST, they sent me the wrong kit, it had male square ends and female oval ends. After I installed the darn thing. So I take it all apart. And send it back. Finally a week later, I get it back. They sent the right kit, yay. I install it. And the inboard light doesnt flash. I check all my connection. They are good. I play with one of the wires that plugs in to the inboard light, and the light flashes for a moment. So I tinker with it, its in all the way, and still nothing. Now im starting to frey the wire. So here I am, still with the uncompleted mod, my trunk tore apart since I spent an hour trying to get it to work. I e-mailed the guy again, I dont know what to do. I have to take apart everything again. What a PITA. The only thing not stopping me from leaving negative feedback is the fact that they are friendly. Im so mad right now. Anywho, id spend the extra $100 and get the plug n play, this whole easier kit is a load of crap. Sorry had to vent. Here is the link to my sale.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWN%3AIT
:notnice: :notnice:
His history is 100%, but I think im going to leave neutral feedback.
Old Apr 23, 2005 | 05:57 AM
2005RedGT's Avatar
I got his kit and it installed easy for me. stinks to hear that you had such a hard time with your installed. G/L with the other kit Let us know how that one goes
-Bryan
Old Apr 23, 2005 | 09:37 AM
adrenalin's Avatar
Sorry to hear you are having such a hard time but that is why I always think it is worth it to pay more for the better equipment.
Old Apr 23, 2005 | 09:44 AM
S197 GT's Avatar
3rd Times A Charm
Can't go wrong with the plug and play for a little extra cadh. It's a matter of how much your time and possible hassles are worth.
Old Apr 23, 2005 | 09:52 AM
KansasCityTim's Avatar
Where are some places to get the "plug & play" sequentials?
Old Apr 23, 2005 | 10:29 AM
Donna's Avatar
Queen Of Nascar
Heres 2 right off the top of my head:
http://www.webelectricproducts.com/products.htm
http://www.classicdesignconcepts.com/catal...isplay/635.html
Old Apr 23, 2005 | 10:45 AM
karrnutt's Avatar
Used Webelectronics harness on my 05 and the kit on the wife's03. Easy to install, both work great, buy quality products. You get what you pay for !
Old Apr 23, 2005 | 10:48 AM
DestinyDE's Avatar
I'll have to second the easiness of using Webelectronics harness. Definitely a plug n play install. Just be care removing those little plastic plugs on the trunck insert...
Old Apr 23, 2005 | 10:52 AM
Does it sequence for the brake lights as well upon initial application, or just for the turn signals?
Old Apr 23, 2005 | 11:09 AM
Sonic05's Avatar
Originally posted by KansasCityTim+April 23, 2005, 11:55 AM--><div class='quotetop'>QUOTE(KansasCityTim @ April 23, 2005, 11:55 AM)</div><div class='quotemain'><!--QuoteBegin-DestinyDE@April 23, 2005, 10:51 AM
[/b][/quote]
They do it for the brakes as well, unless you run a couple wires up to the front of the car.
I am curious about the CDC lights. Are they plug and play? I would go with those for $30 less, but only if they are good quality.
Old Apr 23, 2005 | 11:54 AM
subzero05's Avatar
just out of curiousity was it your right or left tail light?
Old Apr 23, 2005 | 01:04 PM
webeproducts's Avatar
Former Vendor
The CDC kit is not full P-n-P. They give you a pair of plugs that go in-line with the plug that goes between the body harness and the tail light harness. This part is plug-in. However, you then have to punch a hole in the gromment and run a wire out to the inner socket. You then push that wire into the inner socket to convert it to dual function, brake/turn-tail light.
This is less work than the splice-in kit, but not as easy as the pre-wired harnesses that I have. If you return your old harnesses to me, you get a $40 rebate, which brings the fully pre-wired kit cost to $139 -- just about the same price as CDC.
So, you decide. Is it easier to put the effort into wiring the CDC kit, or mailing back the old harnesses to me?
If you have any other questions, feel free to ask here so all can read, or send an email to webeproducts @ adelphia . net.
-L
Old Apr 23, 2005 | 02:21 PM
ravenblack67's Avatar
Talking
I bought the same kit and had a minor problem with the inboard light. I removed the pin and pushed it in again and all was well. Nice kit for $50. My total time was 60 minutes. Try reinserting the pin with needle nose pliers.
Old Apr 23, 2005 | 02:39 PM
adrenalin's Avatar
Tim, do a search on the sequencials under the exterior forum. I posted tons of info regarding installation and how to make the brakes work normally.
Old Apr 23, 2005 | 03:14 PM
Well, I kinda want the brakes to pulse, at least when you initially hit them. I just was wondering if they will continue to pulse as you are sitting at a stop.
Old Apr 23, 2005 | 03:17 PM
Edit: Sorry for the double post.
Old Apr 23, 2005 | 06:06 PM
Donna's Avatar
Queen Of Nascar
With the webelectronic kit, when you hit the brakes they pulse once and then go solid. They don't continue to pulse at a stop.
I have the webelectric ones too and they were very easy to install.
Old Apr 23, 2005 | 06:57 PM
JHL981's Avatar
Okay, i got them working, it was two yellow wires for the inboard light. They are just sensitive in the bulb. It is pretty cool though, neat mod. When i hit the brake mine go inboard, middle, outward, but stay solid.
Old Apr 24, 2005 | 05:55 AM
05passion's Avatar
i have the web electronics that you just wire in ,took 45min. easy mod and they done a great job on the instructions and also have a nice write up on keeping the brake lights from pulsing and if i remember right they also give you the extra wire for that ,not to mention a lifesaver
Old Apr 24, 2005 | 06:22 AM
Redfire05GT's Avatar
I bought the Web Electonics kits and found them easy to install correctly. I appreciate the fact that they are made from original Ford factory wiring harnesses. The fit and function are perfect. I debated whether or not to keep my original harness or send them back for the $40.00 refund. I took it on faith and sent the originals harnesses back. Wow, what a fast refund. Thanks Web Electronnics.
I went for the plug-n-play because I am past my more adventurous phase of life, as far as electronics go anyhow. (After all I did buy a 2005 Mustang GT)
