Sequential Tail Lights
Old Aug 7, 2007 | 01:00 PM
Emperor008's Avatar
I recently purchased a Sequential Tail Lights kit from gtconcepts. Because my car is an 06 built before 11/2005 I got a different type of sequential kit. Instead of changing all three harnesses on all three lights, I just had to change one, and slip a wire into the first bulbs open slot under the rubber gasket. (Sorry no pictures). However, upon finishing the installation, all looked great until the turn signals, or the hazards were kept on for a while (between 10 seconds and 2 minutes), they would then just go out. It can be reset pressing on the brakes again and turning the signal (or hazards) on and off again. Now isn't that somewhat of a road hazard? I can't see if the blinkers or brakes for that matter went out while driving!!! Anyone use this kit or have this problem with the sequential lights?
Old Aug 7, 2007 | 01:06 PM
LEO_06GT's Avatar
I've got the sequentials from CDC over a year ago and no problems here. Then again the CDC kit is plug and play no splicing neccessary.
Old Aug 7, 2007 | 01:31 PM
Emperor008's Avatar
These were no splicing either. It was plug and play. Here are the installation instructions.
http://www.gtconcepts.net/mustang/in...0506/index.htm
Old Aug 7, 2007 | 02:02 PM
ShowGT's Avatar
Sounds like a wiring issue or fault in their design.
Old Aug 7, 2007 | 02:50 PM
2k5GTC's Avatar
I have the webelectrics wire-in sequential taillights. Not a problem here. Sounds like you didn't hook things up right.
Old Aug 7, 2007 | 04:01 PM
Robbieg's Avatar
When the lights go off does the dash arrow still blink or does it go off as well?
Old Aug 7, 2007 | 05:05 PM
RedDragon777's Avatar
i say return if possible and just go for a webelectrics kit
Old Aug 7, 2007 | 05:07 PM
06GT4RAD's Avatar
Should have gone with the Best. True Plug and Play. Money well spent.
http://www.webelectricproducts.com/
Richard
Old Aug 7, 2007 | 05:09 PM
Willie's Avatar
Sounds like either a bad capacitor or transistor on the PCB. Because both sides are independent of each other and the problem occurs on both sides simultaneously, I'd lean towards a bad batch of components that were used. In either case, I'd call and either get a replacement or a refund.
Old Aug 7, 2007 | 05:35 PM
karman's Avatar
+1
Old Aug 7, 2007 | 09:07 PM
Emperor008's Avatar
I'm not going to say I didn't hook it up right, but I did double check all the wiring and my work. I made sure the appropriate wires were in. I contacted the manufacturerer he said to really jam one of the wires in. There is probably no threat to the car because the computer automatically detects a "lamp out error" and shuts it down. That's why pressing the brakes resets it. I'm gonna go back over it again, but if it doesn't work I will ask for a refund.
And it's only the brakes that go out. The front blinkers still work.
Old Aug 7, 2007 | 10:10 PM
Willie's Avatar
I'm sticking with what I said before. It the circuit functions for any number of minutes, then suddenly stops, it's an electronic component, i.e. a capacitor. It's ability to hold a charge lessens with time, then stops working. The symptom you describe sounds exactly like it's a bad batch of components and one (on each side) was used in the PCB.
Willie
Old Aug 8, 2007 | 12:43 PM
TRMN8TR's Avatar
Richard
yep, why waste your time and money with anything else? Webelectric Products all the way!
call the manufacturer and see what they say
Old Aug 9, 2007 | 12:40 AM
kevinb120's Avatar
ditto on the webelectrics
Old Aug 9, 2007 | 07:39 AM
Return it, go with CDC or weelectrics, Ive heard a few bad things about gtconcepts. A good friend of mine has had the CDC's for about 2.5 years, and hasnt had any problems
Old Aug 9, 2007 | 08:54 AM
Parva's Avatar
On the otherhand... I'm totally happy with my GTConcepts Sequentials.
Works perfectly. Have you contacted them yet for tech support?
Found the guys there to be very responsive & friendly; so, it's proably
worth taking a moment to talk to them about this issue.
Old Aug 9, 2007 | 08:59 AM
jacostang's Avatar
Richard
+2 I have them also, works great!!!!
Old Aug 9, 2007 | 09:12 AM
Emperor008's Avatar
I did contact them, I am going to go over the installation. I have had no problem with them at all. Very friendly and helpful. Perhaps I should have used the "best". But why spend 150 dollars, if you can get it for 80 and (hopefully) have it work well. Perhaps it is just my error.
Old Aug 9, 2007 | 09:15 AM
Parva's Avatar
" The Best... "
Ah, ain't marketing a wonderful thing?
Old Aug 9, 2007 | 09:49 AM
TRMN8TR's Avatar
well here is proof that you do get what you pay for. i'd rather pay a little more and not have spend a few days trying to troubleshoot, repair, replace and call tech departments to get something working properly.
the extra money doesn't seem that much now.
