pony emblem hub centers
Originally posted by dtdebuty@April 28, 2005, 3:08 PM
You must take the wheel off so you donyt scratch the wheel as well.
Ummm.. the actual hub center pops off. I need to remove the center of that. just the ford emblem
Originally posted by derynf@April 28, 2005, 4:05 PM
Okay,
I ordered them. I got them in.
Now how the heck do I get the ford thing out with out destroying it.
Okay,
Originally posted by derynf@April 28, 2005, 5:23 PM
I still can't figure this out.
There is no punch out in the back and I'm marring the heck out of the one, I'm working on.
Here's my wheels. I think they won't work.
Originally posted by derynf+April 28, 2005, 7:34 PM--><div class='quotetop'>QUOTE(derynf @ April 28, 2005, 7:34 PM)</div><div class='quotemain'><!--QuoteBegin-derynf@April 28, 2005, 5:23 PM
[/b][/quote]
The pony center caps don't fit on the upgraded rims. Sorry
You're going to sell your caps because yo can' get your Ford ones off? There has to be a way to get them off. I have the Bullitt wheels and my caps came off fairly easily. I think the upgrade wheel caps are more recessed. Someone should be able to tell you.
I am also interested. I have the bullitt style rims on my GT.
-=-=-you have a pm-=-=-
Originally posted by Enigmax@April 28, 2005, 6:08 PM
I might be interested. You have any pics of them?
Sorry, Dude. Someone else beat you to it.
pm me and if it falls through I'll let you know.
When you take the wheel off you will see a circular wire that must be pried off to allow the center cap to be popped off. Once the wire is removed it is easy to push the retaining prongs in slightly to allow removal. When you install the new caps, you reinsert the wire and pop it back in to prevent your caps from easy removal.
The pony caps are not for the upgrade wheels. The only way to make that work would be to drill out the existing cap. It may or may not work I had planned a couple of months back to experiment with the upgrade wheel caps but have been a bit busy. It could probably be Made to work but it will be a delicate operation. I normally stock the pony caps and pony spinners. FYI
kc
kc
Originally posted by derynf+April 28, 2005, 6:17 PM--><div class='quotetop'>QUOTE(derynf @ April 28, 2005, 6:17 PM)</div><div class='quotemain'><!--QuoteBegin-Enigmax@April 28, 2005, 6:08 PM
[/b][/quote]
Not on these wheels.
should have used a toilet plunger stink em off ? I had used a sharp flat edge to pop mine out, as they ship cars with them off so I went down to ask one day and they just sat me in a chair and I watched a while.
and cant wait to put'em on. Thanks again Derynf
