Offset change with wider rim?
Old Nov 29, 2004 | 05:59 PM
Chaotic Bliss's Avatar
I am looking at getting some wider then stock deep-dish 18x8.5 rims. My question is, I am suppose to get less offset (35mm) more offset (55mm) or the same (45mm) if I do not want the tires to stick out? Does the fact that they are deep-dish make a difference or are they all measured the same?
Thanks a bunch.
Rob
Old Nov 29, 2004 | 07:06 PM
steal101's Avatar
All the offsets on wider wheels seem to be higher. I broke down an order custom wheels with a custom offset.
Old Nov 29, 2004 | 08:15 PM
Dan460's Avatar
If the stock wheel is 8" wide and has a 45mm offset it will be roughly 2.73" from the mounting face of the wheel to the outer lip. 8.5" rim with the same offset should be @2.98", only a .25" difference.
cozyp828
Dec 13, 2017 05:53 PM
Autotooner
Nov 24, 2017 12:42 PM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
ricky1728
Feb 11, 2016 07:25 PM
