need some help
Old Dec 19, 2012 | 11:23 AM
atrav83's Avatar
need some help
So I just traded rims and tires with a guy from the forums and on the way home my drive was horrible, the wheel was shaking like crazy at high speeds so I just left CC on at 60, while I was there I noticed one bald tire but didn't really care cuz I wanted the rims and figured I have to replace at least one tire. Now that I'm home and looking at the bald tire it says "inside" on it, so I'm not sure what that means. I plan to take it to get balanced and a new tire this weekend, any help or advice you guys have would be great.
Old Dec 19, 2012 | 11:27 AM
grabberblue 5.0's Avatar
Could be out of balance, could have a bubble on the inside of the tire, could be a bent rim, could be a tire out of round. Inside means that side of the tire should be mounted facing inward, sounds like someone mounted the tire incorrectly
Old Dec 19, 2012 | 11:31 AM
atrav83's Avatar
Ok well looking closely at the rims it doesn't look like anything is bent or damaged, which is why I went through with it, I really hope I just need a balance. As far as the tires go, what so you think I should do about the mismatch? Cuz the front two are the same, but the back two are not
Old Dec 19, 2012 | 01:09 PM
That doesn't matter really, just replace as necessary when tread is low. It's wont hurt anything to have different tires on one axle, but when you replace them make sure they're the same
Old Dec 19, 2012 | 01:19 PM
atrav83's Avatar
Gotcha, thank you for the help!!
Old Dec 19, 2012 | 07:38 PM
delz05's Avatar
If one tire has the word "inside" on it... that tire needs to be removed from the wheel and turned around. You may have rotaional tires, which makes a significant difference in how they ride, if they are not installed properly. Replace the damaged tire for your own safety... and that of other drivers on the road.
Old Dec 19, 2012 | 07:40 PM
atrav83's Avatar
Yea I'm gonna do that tomorrow, thanks guys!
