Mach 1 Conversion
Mach 1 Conversion - Need some opinions!
I wanted to get some more opinions on the start of my "Mach 1 Conversion" project. I attached some thumbnails, but there are a total of 32 pictures located HERE.
I bought the 18" Black Bullitts before I knew I was heading in the Mach 1 direction, so I have been thinking about selling those rims and going with these: (anybody want to buy some brand new 18" black bullitts? )
(but I would still use the Pony center caps)
So far, I added the CDC Shaker Kit and the CDC Classic Chin Spoiler. Also, I found a new "take-off" black rear spoiler on eBay for really cheap.
In the near future, I'm adding the Mach 1 hood stripes from Graphic-Express found in this LINK. Also, I will probably add the rocker stripes found HERE, but I don't want it to say "Mach 1" since it really isn't a Mach 1. Also, I'm not sure about the horse.
Anyway, please let me know what you think... good or bad. Or any other ideas that you think maybe I should do next. (Still have to get my dang windows tinted!)
Thanks!!
Thanks!!
Originally Posted by StangNut
Looks great!
How much are you thinking about asking for the wheels? (I assume they're the ones made by WheelReplicas)
The quality was excellent. The Mach 1 rims would cost me as much as the Black Bullitts ($684 including shipping). I would have to order them first so I could have Discount Tire swap the tires over (which will cost me approximately $44 unless I can get them to do it for free).
If I got $475 + shipping for the rims, it would cost me an extra $253 just for my mess-up. I guess I could live with that, but that's if I get that much for the rims. So I'm in a pickle...
Looking good. The new cervini hood and grille ext. would really complete the look IMO.
I fail to see where a Cervinis hood extension (or hood) would add to the desired Mach 1 appearance also.
Originally Posted by uberPony
-Cowtown
I definitely won't be changing the hood, though, after all the trouble I went through making sure that that hole was exactly centered! Actually, it wasn't that much trouble, but we (my dad and I) did a lot of double and triple checking before I made the cut!
Tom,
The AFS Mach wheels should look great on your car. I noticed that the hood stripes you want to use are designed for the '04 style hood. Make sure you ask the folks at Graphic Express if that kit will fit the '05 hood before you order. The '05 hood has a slight crown to it and we had to cut a slit in the center of the wide section of the vinyl to prevent it from bunching up at the front edge.
Best of luck with your project!
Attachment 4109
Use a plain black stripe, unless you want something else in the rocker stripe.
Is the car going to stay white?
Also, you might want to add some rear window louvers. They add a good retro mix to the car. I was thinking something like Packman's GT.
http://forums.bradbarnett.net/showthread.php?t=49577
Your car is looking great, I vote for the mach 1 wheels. Better yet I would put a set of Magnum 500 Billet Aluminum wheels from Newstaliga Wheel.
http://www.newstalgiawheel.com/listp....asp?cat=10115
The slit is about 15 inches long from the leading edge of the decal and overlaps to a maximum of 1/4". It's only noticable when scrutinized from close range, though. My stripe also ends at the "downturn". Here's a closer look...
You're right... can't tell at all in that pic. *Wondering if I'll have the same problem with mine*
Think I should put the upper stripe on, too? (between the scoop and windshield) Click Here
Just wondering if it will be "too small"... your part looks good in that area that runs around the scoop, though!
I have the AFS 18x9 Mach 1's and love them. They weren't my first choice but now I really like them. I get quite a few comments on them too.
Originally Posted by osu_p51
AFS Mach 1's, g-force kdw 255/45/18 front 285/40/18 rear
Originally Posted by Shea
I would be interested in buying your black bullitts if they were deep dish.
