Hood pins?
Old Apr 7, 2011 | 08:09 AM
07AlloyGhost's Avatar
Hood pins?
Who has functional hood pins (NOT the stick-ons. . .)? Likes/dislikes? I am not planning on breaking any land/speed records (yet *evil grin* ) but I think they look tough. Concerned about the cables scratching the paint, but think they look kind of silly without the cables. . . opinions?
Old Apr 7, 2011 | 08:44 AM
05YellowGT's Avatar
Here's mine , never had any problem with the cables scratching the paint
Old Apr 7, 2011 | 12:58 PM
Thanks - those are nice. Found this post and like these as well: https://themustangsource.com/f691/ho...-hoods-488967/
Old Apr 7, 2011 | 02:06 PM
05stangkc's Avatar
Cables Pretty much always rust down the Road in my experience. Love the twist locks. 05-09 Hoods do like to float & wobble at speed. At least in my 05 topped out it did! Just tried that once.
Kc
Old Apr 7, 2011 | 05:55 PM
D'prived's Avatar
I like the hood pins but didn't like the lanyards.
With the lanyards...
Without...
Old Apr 8, 2011 | 07:58 AM
smitty_45th Pony's Avatar
i got mine from UPR. Real easy to install. They replace the raditor braces. Use a step bit and go slowly it makes drilling the holes so so easy
Old Apr 8, 2011 | 08:26 AM
Thanks everyone. I think I am gonna go with the ones from upr. I'm having custom stripes painted on and they said they would install the hood pins for me too.
Old Apr 8, 2011 | 11:18 PM
ETNOATS's Avatar
Ive had the Scott Drake ones for a year or so and the cables are rusting, like them though and do keep the hood tight as a drum.
Old Apr 10, 2011 | 01:05 PM
UMich97's Avatar
Anyone have anymore tips on drilling? I'm installing a set of the Shelby Hood Pins in a few weeks and the more tips/insights the better.
Old Apr 10, 2011 | 01:07 PM
11SHELBYGT500's Avatar
They sell an install kit and the cables should be plastic coated.
Old Apr 10, 2011 | 01:10 PM
Without...
Pins too close to the center IMO
Old Apr 10, 2011 | 01:42 PM
GRAYPNY's Avatar
I have had hood pins from almost day one. I have the Ford Racing pins and have the lanyards tucked under the hood pretty tight so they don't flop around in the wind.
Installation tips:
1. remove the hood liner
2. install the pins where you want them on the brace
3. put some marker powder on the top of the pins
5. gently close the hood so the powder will transfer to the hood
6. use a step bit and slowly drill the holes.
7. good luck
Attached Thumbnails Hood pins?-engine-004.jpg   Hood pins?-gt2.jpg   Hood pins?-dscn0062.jpg
Old Apr 10, 2011 | 04:22 PM
UMich97's Avatar
Thanks Rich....quick question. Do you drill from the underside of the hood for the full hole, or start from the underside and finish from the topside? Not sure if it matters, but just figured I would ask, as I'm sure when I first start to drill, I'm going to be a bit nervous.
Old Apr 10, 2011 | 04:57 PM
GRAYPNY's Avatar
I started on the bottom and finished on the top. It never hurts to put some painters tape on the hood when drilling.
Old Apr 10, 2011 | 04:58 PM
DynamicmustangGT's Avatar
I did mine from the top and went right through. I used pre-existing holes in the radaitor support to mount the pins. Make sure to go slow and take it easy. I also used paint on the metal that I drilled through.
Old Apr 10, 2011 | 05:09 PM
UMich97's Avatar
Thanks guys. I've got painters tape and touch up paint in my tool box, so I'll keep those handy when I drill. I'll also pick up a step bit for drilling and maybe a center punch? Does the type of step bit matter?
Sorry so many questions, just never really drilled any metal before and would rather be safe than sorry.
Old Apr 10, 2011 | 05:25 PM
http://www.sears.com/shc/s/p_10153_1...3&blockType=G3 I used this bit, but any type of metal step bit will work, just make sure to measure twice before drilling once. The hole also needs to be slightly larger than the pin because the hood needs to open and close over it.
Old Apr 10, 2011 | 05:41 PM
GRAYPNY's Avatar
I also put some liquid aluminum in the are where I cut the holes. You know that our hoods are hollow in the center?
Old Apr 10, 2011 | 08:09 PM
UMich97's Avatar
Thanks guys, appreciate the help. You know, I guess I realized the hood was hollow, yet it didn't even cross my mind on how to address that. Makes sense you'd want to fill it with something. Also makes sense why you'll want to be careful both when drilling and when attaching the hood pin plates, so as not to dent the hood. I know when I removed my spoiler, I had to be pretty careful too, as that metal is pretty thin.
Note, I've never used liquid aluminum before. Pretty straight forward? Assuming it's a puddy type substance?
Old Apr 10, 2011 | 09:26 PM
GRAYPNY's Avatar
I never installed the bottom plate either. You don't want to dimple your hood and it will be fine without it. Just squeeze some of the gunk into the gap and remember your not trying to fill the entire hood. LOL Some sort of puddy might even be better.
