Help
Old Jan 7, 2006 | 03:35 PM
goat678's Avatar
can somebody tell me how to change the fog light bulbs thanks
Old Jan 7, 2006 | 04:17 PM
sodaman's Avatar
yah its pretty easy
first take the radiator cover off, remove the plastic retainer plugs holding it on.
then you will see the bulb areas below the cover. I believe there was one bolt on each side, that you can remove and will give you just enough room to get your hand down there and change them out. I found that it was actually a little easier to unplug from top, then stick my hand through the bumper opening and up you will have more space to remove the bulbs themselves. But like I said if you want and are able you can also do it from the top. I did one , one way, and the other through the bumper opening. good luck pretty easy
