Help!
Old Dec 17, 2005 | 10:53 AM
brad25's Avatar
I have had the CDC sequintal taillights installed for about 2 months now. Today on the way home from work I noticed that my right blinker was blinking really fast. I thought I might have a burnt ou bulb but they all light up when I turn on the hazards, lights or break. Is there a flasher somewhwere in the car that might possibly gone bad? I could not find one. I double checked all the connections and nothing is loose, any help? thanks, Brad.
Old Dec 17, 2005 | 11:08 AM
adrenalin's Avatar
disconnect the sequentials and see if you are still having the problem.
Old Dec 17, 2005 | 11:29 AM
brad25's Avatar
I tried diconecting them , I unplugged the white connectors but the black wire that runs to the first bulb locks in place. Is there any way to get it out with out cutting it?
Old Dec 18, 2005 | 07:41 PM
GrayBeardGT's Avatar
If one side is working right and the other is blinking fast, then it isn't the flasher. Check the front turn bulb too. If any bulb is out (or not wired correctly) it can make the lights blink faster than normal. I would also contact the tech support folks at CDC, they are very helpful, too.
