GT500 conversions using the GT/CS rear bumper...>>
Old Nov 13, 2006 | 07:11 PM
Willie's Avatar
What did you guys use to paint the sides of the bumper to match the rear (between the tailpipes)?? If you painted the entire lower section, what did you use?
Either way, does the color match the unpainted front chin spoiler? I'm assuming you guys used the unpainted side rockers from a V6? I need to know by tomorrow (11/14/06) as my parts are being painted then.... Thanks!
Old Nov 13, 2006 | 08:28 PM
StangNut's Avatar
That rear section is part of the bumper cover. Along with those side areas. It's all one piece.
All 4 areas are one part:
1. Rear Center Section
2. Bottom Strip - Right Side
3. Bottom Strip - Left Side
4. Bumper
Since they are all the same, in order to match the unpainted rear center area, you would leave the bottom strips on each side unpainted also.
EDIT: I just re-read your post and I'm assuming you already have the parts so you know already everything I just wrote.
I can tell you from experience, flat black sprayed with a clear coat is shinier than the V6 rockers.
Old Nov 13, 2006 | 09:13 PM
Willie's Avatar
Yes, I have the bumper cover. Please see my reply (#10) here:
http://forums.bradbarnett.net/showth...924#post779924
Willie
Old Nov 13, 2006 | 09:14 PM
StangNut's Avatar
Got it.
Fords4Ever
2011 - 2014 GT/CS
21
Mar 1, 2021 12:22 PM
Fords4Ever
Oct 30, 2015 09:07 PM
Cdvision
Sep 5, 2015 05:22 PM
JTB
Motorsports
Sep 3, 2015 10:50 AM
