GT/CS rear bumper, hardware question
Old Jul 2, 2010 | 07:20 AM
Shotokan1509's Avatar
I gave my car a quick rinse this morning and noticed the rear bumper seemed loose in the center, directly in center under the car is a mount. What is that piece supposed to be holding it? Mine looks like one of those pop rivet things used on the front wheel well liners, but it was set to "lock" yet very loose. Yes I know those things break all the time, but wondering is that the correct replacement or was something else supposed to be there?
Old Jul 2, 2010 | 07:44 AM
fdjizm's Avatar
It connects to the under body so it doesn't flap in the wind, there are two of them, one of mine broke had to zip tie it back.
Old Aug 12, 2010 | 08:52 PM
Little Black Pony's Avatar
I just had a GT 500 bumper put on my stang so i got to see everything before it went on. The GT/CS (GT 500) rear bumper uses three push pin connectors to hold the bottom of the bumper cover in place. The center push pin is generally pretty loose, but shouldn't fall out. It's a super bad design for the middle bumper hold.
Old Aug 17, 2010 | 07:27 PM
spike's Avatar
Thanks to the body shop when they couldn't find the hole to attach the center tab to, they cut it off. Nice huh? So I added two tabs of my own made out of shaved down plastic spackle knives, 3M tape, and two existing bolts. I know.. sounds like it belongs on thereifixedit.com but it's now more sturdy than the original bumper. The 3M tape is used to attach the tabs inside the flat part of two of the diffusers.
Old Aug 18, 2010 | 02:58 PM
I like the idea of having two tabs in the middle using the stock bolts. Great fix Spike!
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
Ecostang
Nov 3, 2022 08:50 PM
mrp5150
Aug 23, 2015 06:29 AM
glo106
Aug 11, 2015 08:29 AM
stewarts359
Jul 31, 2015 08:46 PM
