Fatter tires out back
Big Falken Tires
Sooner or later, I will have to replace my Nitto 275/40s I am running out back... (probably sooner)
I have always wanted something a bit taller in the rear (but not sacrifice width/contact patch) to fill up the wheel well more.....
My issue - I see that Nitto now has a 285/40/18, so I am trying to decide between that and their 295/45/18s, which I have already thrown around for a while now...
My issues:
I am running nine inch rims. The Discount Tire guy told me the 295s would fit on the 9 inch rim. So I was leaning towards those - I don't mind the car getting a bit more of a forward rake again... the only issue is, on the Nitto size chart on their site when comparing sizes, the overall diameter they have listed was done on a ten inch wheel. Naturally I would guess running the tire on a nine inch, would make the tire sit a bit higher still. So I don't want TOO much extra height in the back....
I have seen a handful of guys with Nitto 295s out back but they are all running 10 inch rims....
So I keep coming back to getting the 285s because I really can't afford another set of rims for the rear just to get those 295 tires....
Anyone running really fat meat on a nine inch rim here and if so what kind??
My issues:
I would like to run 305x40x18 on ten inch deep dishwheels but I have steeda springs and not sure if they would rub the fender or not. Done anyone have first hand knowledge? THANKS
I have heard from The Discount Tire guy as well, that 305/45R18 on the rear will work if the car has not been lowered, but you have to watch steep grades so I am guessing it would be close there is a 1.2" difference in overall diameter between the two and the Steeda springs lower our cars 1.25"
