Eleanor style grille owners, I need some help!!!
Old Dec 22, 2009 | 10:02 AM
texasgt/cs's Avatar
Can someone give me the dimension from the outside of the fog lights. I am trying to find out if they will
line up inside the single stripe I have on my car
thanks
Old Dec 23, 2009 | 08:09 AM
mustangpowers's Avatar
are you looking for a measurement on the lower fog lights from side to side?
Old Dec 23, 2009 | 10:23 AM
STL-GT's Avatar
Which Eleanor grille do you have or are you looking to get? I believe each one is slightly different in spacing for the centered fogs. Also, do you mean upper or lower Eleanor grille?
Old Dec 23, 2009 | 11:38 AM
05YellowGT's Avatar
I don't have it on my car anymore , but if you're talking about the type in Jeff's avatar , when I bought mine there were a couple of different makes and the distance between the lights varied. Just an FYI ...
Old Dec 24, 2009 | 10:29 AM
texasgt/cs's Avatar
yea I guess I need to decide which one i want
Old Dec 24, 2009 | 11:37 AM
STL-GT's Avatar
If it helps make your decision, the one that I have on my TR is the 3d Carbon Eleanor Grille. The overall length from the outer edges of the black bezels around the fogs is 15.5." The center spacing between the black bezels is 1.25."
Old Dec 28, 2009 | 08:29 AM
texasgt/cs's Avatar
thks STL, I guess the dimension is going to determine which one I finally go with, I want to keep the fogs inside the stripe dimensions.
Old Dec 28, 2009 | 09:59 AM
STL-GT's Avatar
How wide is your stripe?
I actually think it would look pretty cool if the fogs set just outside the edges of the stripe, especially if the stripe extends down over the bumper. It would add a bit of a break to the clean lines of the stripe on the front of the car... Just my 2¢
Old Dec 28, 2009 | 10:51 AM
texasgt/cs's Avatar
17 1/2" over all., btw in your earlier post you mentioned a lower grille, who makes those, that might be even cooler.
Old Dec 28, 2009 | 11:42 AM
STL-GT's Avatar
So it sounds like the 3D Carbon grille would work for you. You'd end up with about an inch on either side of the lights inside the stripe. Also, depending on where you buy it, it comes with the tri-bar pony emblem.
See mustangpowers avatar for the lower grille. He can correct me, but I believe that one is Cervinis, and it may have to be done with the entire bumper.
Old Dec 29, 2009 | 09:25 PM
texasgt/cs's Avatar
you are right about the Cervinis.
TripleBlack14
May 10, 2016 04:30 AM
GLOCKer
Sep 28, 2015 05:20 PM
