daytime running lights from headlights to grill lights
Anybody done this ?
I want to change my daytime running lights from headlights to grill lights.
I have a 06 pony pkg
SiBEERian (12/5/16)
Tms Mustang Member ------ The Customizer!
yes Ive done something like this. Ive changed my DRLs from headlights to Angle eyes.
Since Ive asked this before and figured it out myself since no one knew, Ill help you best I can... You need to by pass or reroute your DTL system. Reroute the proper wires to your fogs lights. Just know you wont be able to use your fogs light switch any more. I believe it is the Yellow wire that is your DTL uses that youll need to give power to your Fogs. You might also need a relay switch (I needed two of them) and a resistor but let me double check and get back to you.
I solved this problem so:
http://www.mustangclub.ru/forum/topi...F%D1%82%D1%84/
