Day Time Running Lights - need help!!
Old Apr 27, 2008 | 07:39 AM
Mustang Sherry's Avatar
Unhappy Day Time Running Lights - need help!!
I installed the WebElectric DTR lights on my 08 GT/CS and can not get anything. I still have turn signals and everything else but the DTR's do not work. I did start the car and have the E break off and checked the wiring diagram 8 times to make sure that it was hooked up properly, but still nothing. Anyone have any ideas that I can check?
Old Apr 27, 2008 | 12:19 PM
Deric's Avatar
Is anything else off? Do the headlights work via the switch. If not you might check your fuses. Also you know the dealer can turn DRL's on through the computer right? You don't need to install anything for it. It is controlled by the SJB. I know a few owners who had them after a SJB replacement or who went to the dealer to have them turned on.
Old Apr 27, 2008 | 12:39 PM
Everything else worked just fine. Head lights, turnsignals, everything. I will look into the factory set up. this may be a better option. Thanks!!
Jim74656
May 1, 2023 02:15 AM
Diode Dynamics
Jun 12, 2018 03:26 PM
ustabawannab
May 3, 2016 07:54 AM
FarmAnimal
Aug 3, 2015 05:53 PM
Extremespeedtrackevents
West Coast
Jul 9, 2015 11:26 AM
