cdc shaker scoop drainage tube question
Old Mar 27, 2011 | 02:24 AM
sound wave's Avatar
tried searching, but i guess i am not good at using the correct key words.
i had a question about the drainage tubes that come with the cdc shaker scoop. i have an 07 gt. 3 of the tubes i am semi-satisfied with their location. i am a bit concerned about the driver's side front tube. i can't find a good place for it. it seems either the water will go all over the belts and/or electrical stuff or the other choice is to have it dump on the header.
i was wondering what solution others here have found. thank you in advance for any help.
Old Mar 28, 2011 | 11:28 AM
azoufan's Avatar
Buy more tube and route it where you'll be happy. I just bought a bunch of it from Ace and used plenty of tie wraps and routed it to drain away from everything else. I'd take a picture, but it's pathetically dirty and I'm too embarrassed to show my engine bay.
Old Mar 28, 2011 | 04:21 PM
sound wave's Avatar
i think i may have to end up doing that.
didn't seem like many people were having to do that (or at least weren't mentioning it).... that is why i was wondering where they ended up placing the supplied hose. thanks for replying btw.
Old Apr 2, 2011 | 09:45 PM
aircare84's Avatar
Few pics showing (kinda) my routing for the forward drivers side drain hose.
I do have a 06, may be some differences.
Old Apr 2, 2011 | 09:48 PM
aircare84's Avatar
Pics this time
Attached Thumbnails cdc shaker scoop drainage tube question-gt-096.jpg   cdc shaker scoop drainage tube question-dsc05021.jpg
Old Apr 2, 2011 | 09:53 PM
sound wave's Avatar
thanks for the reply. what is directly under where your hose ends?
i am going to try and incorporate that type of weatherstripping you got around the scoop.
i took my car to a drive in car wash today and my turbo pipes got a bit wet from the excess water.
is that some sort of special weatherstripping you have? or is it the type from the hardware store? thanks again.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
