CDC Ducktail - Installation options
1 Post
Question for those who have installed a CDC ducktail - did you drill holes, or cut the mounting studs and use adhesive on the end pieces?
I have a Mystery 7 hood / nose, and we used windshield adhesive to secure the eyebrows and grille ends. No problems - tight, solid fit. The studs were cut off of the grille ends since I did not want to drill holes into the front fascia.
I am not crazy about drilling holes for the side pieces of the ducktail and I am considering using the same adhesive.
Any thoughts?
Any thoughts?
As it's going to be deflecting the air, and air pressure can be rather great, I'm of a mind that unless the adhesive is of space shuttle tile glue (and even then, they have tiles go missing...) that piece needs to be bolted on.
But that's just me thinkin' from a semi-scientific point of view... your eyebrows probably catch air too, and apparently aren't affected by non bolting... although that could also be helped by the placement. As in, it's gettin' pushed on, versus being pushed off, as would be the case for the spoiler.
Worst case is that you glue them, lose them, and then you know... I'd be drilling.
1 Post
Having just installed mine, I would drill the holes. One piece of advise, when drilling the lower holes in the trunk lid, make sure you don't drill into the plastic part of the brake light. I just bumped mine when the 1/8" drill went through. Keep the trunk open slightly when drilling!
By the way, I think it is the best spoiler on the market, hands down.
1 Post
Now that I have it out of the box, I see that there is hardware for the center piece. The ends have the studs built it. So it looks like poking holes is the way to go... (insert cliche Tiger Woods joke here ) ![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
Too cold to fool with it now - probably an early spring project for now. Thanks for the input!
I don't do trannies
or rear-ends anymore!
Well, as usual, I'll go against the grain. I couldn't make myself drill on it, and simply used a good adhesive from my local shop. Work fine for a few thousand miles, it's off the car at the moment after an incident while it was at the shop on a lift as I've been to busy/lazy to get it to be repainted. If I had drilled it, I would have a bunch of goofy holes in my lid right now as I drove around, so I was pretty happy I didn't! ![Cheers](https://themustangsource.com/forums/images/smilies/cheers.gif)
I will say the stuff that came with it sucks though. I test fit it with that and none of the corners on the corner pieces would stay flat, they look much nicer with tube adhesive.
1 Post
Hmmm... Can you elaborate some more on your comments -
"I will say the stuff that came with it sucks though. I test fit it with that and none of the corners on the corner pieces would stay flat, they look much nicer with tube adhesive."
Just curious...
Just curious...
Diode Dynamics
6/12/18 03:26 PM
