Anyone running 275/40/18s on the front or even all 4?
Anyone running 275/40/18s up front, or even all the way around? If you are, give me any pros & cons if you don't mind, and please post some pix.
Thanks,
Tom
Thanks,
Tom
275/40/18's all around
I bought my car used and had it delivered directly to a body shop for mods. I never drove it with the original wheels and tires, but I have to believe there wasn't the road noise that I know have with the 275 tires. The front tires are flush with the top of the fender wells, so they kick dirt, rocks, etc. up on the front quarter panels directly behind the wheels.
I really like the look and the ride on the 275/40/18's
This is not a daily driver so I would definitely go with the 275's again. If I had to drive it everyday, I would probably go with a narrower front tire.
Best photo's I have, sorry.
http://i133.photobucket.com/albums/q.../leftfront.jpg
http://i133.photobucket.com/albums/q...g/rearview.jpg
http://i133.photobucket.com/albums/q.../topupside.jpg
http://i133.photobucket.com/albums/q...opdownside.jpg
I have 275/40/18's all the way around. I too have increased road noise. I love the look and the car handles great.
I will have to switch out my wheel combo for the track, but in my opinion that isn't a big deal.
Hey Tom,
Well, I can't show you any pictures yet but as you can see from my sig I will be running them soon. I talked with Steeda several time about what is the widest tire and wheel combo I could run on all 4 corners on a stock ride height car. They said 275/40/18 safely. The rims I am getting are 9.5 wide with the proper offset. They also said if I planned on lowering the car I might have rub issues in the front only. The rears would be fine. Since my car is a daily driver I need to be able to rotate the tires so I will probably will not lower my car. Steeda tells me they should ship in 2 weeks now. So I get pics someday.
Scott
Scott
Hey Tom,
Scott
Scott
Yes sir...got the entire package from them. Rims,tires,mounted,balanced,nitrogen filled and delivered to the door. Also comes with new chrome lug nuts. You can work a little better deal with them then what you see on their website.
Scott
Scott
P.S. I went out on the web to see what other advantages there was to nitrogen filling tires and one additional thing I read was it does not oxide aluminum wheels like regular air does.
Man, I gotta admit I'm alittle shocked at tire pricing. You gotta remember, the only tires I've purchased in the last 4 or 5 years is for my '92 GT- 245/45/16. Top shelf BG Goodrich Comp TAs were like $130.
I have them all the way around. FRPP springs
The cons :
1. They like to follow the ruts in the road
2. Toe setting is more critical. Proper toe helps minimize #1
3. Slight increase in road noise
4. Slightly harsher ride compared to factory. Of course, that also depends on tire/sidewall construction
Pro's :
1. More contact patch
2. Better turn in
3. Fills the wheel well better
4. Looks better
5. I like it better
The cons :
Pro's :
2. Better turn in
4. Looks better
5. I like it better
Guys w/ aftermarket wheels and 275s--
What are the specs on your wheels? Specifically: Diameter, width, and offset?
