Anyone relocated their horn from the front grill?
I had the front bumper off the car doing some other mods when I decided I'd take the horn out and see how it looked. It looks a lot better not staring at me behind the Bullitt grill. Problem is I need a horn. I think its a law or something.
Has anyone here relocated their horn? If so where did you put it?
I made this grille out of a Shelby surround and some wire mesh I got from McMaster-Carr. I made a stainless bracket for the Shelby Tri-Bar Pony and bolted it to one of the vertical supports.
I moved my horn(s) to the lower Right, just behind the washer bottle, behind the bumper cover. I used the factory bracket and an existing bolt that was mounted to the bumper support. I then drilled a single secondary hole and as I installed a second bolt, put some silicone sealant there to avoid any corrosion from breaking the integrity of the paint with the drill hole.
You can use the stock bracket and the wiring harness for the horns can be rerouted such that no splicing or cutting is required. This will allow you to go back to stock in the event you ever sell the car. Also, the sound from the horn is unchanged outside the car when used.
I was going to go to the drivers side initially just because there is so much room over there, but this will be much better.
To remove the horns in their present mount take off the cover over the top that fills between the grille and the rad, disconnect the wiring harness and remove each horn separetly from the mounting bracket and drop out below. Now undo the mounts for the bracket and drop it out the bottom. Take the mount bracket and use a cold chisel to break the two spot welds and discard the bottom half. Take a hammer and knock out the stud on the top piece you have left with the holes for the horn mounts. You will need a 1/4 inch fender bolt and nut to remount this piece to the hole in the headlight bracket through the hole left when you removed the stud. Now remount the horns in a downward facing position and tighten the nuts and reconnect the wireing harness after you reroute it to the new position. You will want to be careful about the positioning before you tighten down everything to avoid any contact with any metal that might cause a vibration. I found it very easy to achieve. The only problem this remount might cause is a removal of the large harnesses for the computer. Good Luck
Well I relocated down to the driver side behind the front marker in the bumper. There was an existing hole that I just slapped it in. It will be completely out of sight there and still plenty of room. I will have to extend the wires though, but the passenger side was not good for me as my intercooler water pump was in that location, and while I could have tried to fit it, this just worked best. The best thing is my Bullitt grille is now completely clear behind it and it looks so much better. I even sprayed the condensor coil with a few coats of flat black and I can't imagine it looking any better than it does now. I will post pics later. I'm still working on the the lower bezel fog light install. A huge PITA when you have a giant heat exchanger for an SC in the lower grille.
I just finished doing this mod and here's a Before/After pic andmore picyures that are a little clearer for thos who want to try it..
BEFORE
AFTER
This is where the bracket is relocated.
BEFORE
AFTER
