Aftermarket 2005+ Mustangs Discuss the Offerings from Roush, Saleen, Steeda, Shinoda, and Others
Updated CDC info
Old Nov 29, 2004 | 02:00 PM
Stangfriik's Avatar
NEW PRODUCT FAQ Sheet
Timing - All 05 Products (that were displayed on our Red Show Car) will be
released between now and April 2005, with additional products to follow.
Gauge Pod
Designed & Manufactured by CDC
Finish - Molded in black with paintable smooth finish or molded with
matching grain and color
Material - High Temp ABS
Gauge Availability - Gauges optional
Attachment Process - Bolt down or acrylic bonding tape (process at
owners discretion)
Glassback Roof -
Available through authorized dealers
Shade is not required due to the UV protection with solar reflective
and solar tinted and is standard in the glass (99% UVB protection)
2 Color Styles available (Silver Metallic - Smoke Metallic)
Optional Chimsl Light
C-Pillar Scoops
Smooth Scoops
Material - Injection Molded Urethane
Louver Scoops
Attachment on Both - Hard mount system to window no drilling
required.
Shaker
Fully Functional Cold Air System
Adds HP
Trim Ring Standard - No Appliqué (Not required with the 05 Styled
Hood)
Optional Styled Hood
Chin Spoiler
Designed & Manufactured - CDC
2 Design Options -
Classic Chin Spoiler - Attached with plastic push pin
fasteners
Aggressive Style - Requires Fascia modifications. Modifications will
increase air flow to after cooler or radiator
Hood Scoops
Designed & Engineered by CDC
Standard with Signal Indicators
Grille
Brushed aluminum with lights
Brushed aluminum without lights
Mesh Styles
Rear Deck Spoiler
Material - Blow molded ABS
To simplify installation process order your Mustang with Spoiler
DELETE option
Hood Pin Appearance Kit $58.00
Authentic Hood Pins. But these Hood Pins are unique; they do not require drilling into your hood. You just adhere them to your hood using the 3M bonding tape that is standard on this Zinc Die Cast, Chrome Plated, weather resistant hood pins. The lanyards and pins are stainless steel to maintain the quality appearance. Best yet they work on every vehicle; early, late, domestic or imports.
Old Nov 29, 2004 | 02:43 PM
Greywolf's Avatar
Cool thanks
Old Nov 29, 2004 | 07:00 PM
WBstangGT's Avatar
so the CDC hood is supposed to be fully functional ram air? that is awesome, and thanks.
Old Nov 30, 2004 | 03:53 PM
dkuhne's Avatar
Thanks for the update!!
Jul 8, 2016 08:53 AM
boz
Oct 1, 2015 04:47 PM
GLOCKer
Sep 28, 2015 05:20 PM
lowblustang00
Sep 25, 2015 10:12 PM
scott6809
Sep 12, 2015 11:44 PM
