X-charger installation pictures...
Old Jul 4, 2006 | 07:39 PM
Doug@C&L's Avatar
Hey guys,
Here's some installation pictures and uninstalled kit pictures.
Unfortunatly I dont have any pics of the lower intake upclose but maybe the other guys that were there do. I have tried to show a picture I took of it.
Just a few quality peices that I can reference are the completely cast new intake manifold, the intake to the back of the supercharger which we drilled and tapped for the water injection unit with no problems, the front drive plate and pullies along with the nose support for the supercharger Ford doesn't even supply this on their factory units. Not to mention all of the small fittings and parts and even though you have to cut 4 wires the butt connectors that are provided aren't your run of the mill connectors. Once the connector has been crimped you can heat it and the heat shrink at either end wil seal the connection and the SOLDER in the middle melts to further ensure the complete circuit makeup.
The instructions are very detailed with alot of pictures and even though we ran into some misinformation about the plug wire setup we fixed it by swapping the end two plugs. After further review of the instructions they were right and we were just confused, that is going to be addresses in the production instructions.
Feel free to ask any questions you may have....
http://users.wildblue.net/bamachips/...X-charger1.jpg
http://users.wildblue.net/bamachips/...X-charger2.jpg
http://users.wildblue.net/bamachips/...X-charger3.jpg
http://users.wildblue.net/bamachips/...X-charger4.jpg
http://users.wildblue.net/bamachips/...X-charger5.jpg
http://users.wildblue.net/bamachips/...X-charger6.jpg
http://users.wildblue.net/bamachips/...X-charger7.jpg
http://users.wildblue.net/bamachips/...X-charger8.jpg
http://users.wildblue.net/bamachips/...X-charger9.jpg
Thanks, Doug.
Old Jul 4, 2006 | 07:47 PM
Torch_Vert's Avatar
That install is too sweet looking for words....
I am soooo glad I'm going the X-Charger route
I'm really impressed with the attention to detail on the "little" things like the belt routing sticker. Nice.
Old Jul 4, 2006 | 07:49 PM
94tbird's Avatar
is that intercooled or no? it looks like a very nice kit and very clean instal along the lines of a kenne bell
Old Jul 4, 2006 | 07:56 PM
Thomas S's Avatar
That looks sweet! Love the CAI.
Old Jul 4, 2006 | 09:08 PM
hamidlmt's Avatar
Dig it!!
Old Jul 4, 2006 | 09:09 PM
Doug@C&L's Avatar
There are so many little extra's that is with this kit I cant begin to list them all. As you've mentioned, and I forgot, the belt routing decal along with another that says 91 octane or above, X-charger, and soon to be " 50 States Emissions Legal" . Each of the parts came in seperate bags that including all of the parts for that step of the install, if they were small enough to fit in the bag that is. The injectors are brand new from ford, 39lbs Cobra's. There are bolt holes in the spacer plate that are locator holes and are mechined within tolerances and it says on the instructions to install this bolt first and then gives a bolt installation sequence and torque spec.
As for the intercooler, there's just not enough room below the charger as it sits, if we were to include a charger then it would require the hood to be raised or some form of cowling. Of course when you do this you'll also add 25-35 rwhp and that will make things not as long lasting when it comes to engine life. Not to mention the added cost of the intercooler, pump, heat exchanger, tank and lines. It maybe a add on for future reference but for now I would recommend running it as is for daily driving and then when you goto the track run water injection, maybe even methonal if you have it tuned for it.
Finally, the new CAI is part of the 49 state kit, for now it doesn't have a heat sheild but it will to help keep underhood temps from going into the charger.
thanks, Doug
Old Jul 4, 2006 | 09:33 PM
BurntPony's Avatar
Looks great, a couple questions:
Does it use a oem GT MAF? If so can a oem GT airbox be retained?
How about the upper radiator hose? Is that preformed or a flex hose?
I thought water injection would prolong engine life, not reduce it, unless you went with crazy amounts of boost. I seem to recall the Jackson Racing supercharger for the 2.0 Focus advertised a temp reduction of nearly 100 degrees with water injection.
Is the new manifold higher than the oem? Will a strut bar still fit?
Anyway looks great, cant wait for pricing and availabilty.
Old Jul 4, 2006 | 09:51 PM
Doug@C&L's Avatar
The 50 state kit comes with a GT airbox lid, the V6 is the same on the lower. Then you'll use your MAF sensor, there again the same as the GT.
It is a flexhose for the upper hose but it now has a covering to look more stock. With the covering you can't even see the flex.
The water injection will make for lower air temps and when used moderatly can help power, truthfully though Water injection should never be used as a way to make a vehicle suitable for daily driving, you'd need a water bottle the size of your gas tank. Also though, if you're gonna go through the process of installing it then why wouldn't try to get the max from it? In short, it would help power without a tune and be even more helpfully with a tune for it.
Thanks, Doug.
Old Jul 4, 2006 | 10:59 PM
Tres Wright's Avatar
Wow, that is really a beautiful kit! All the components really look top notch. Doug, I saw in the other thread that you mentioned it took you about a day on the install, but that you were slowed down some because you were assisting on the instructions. What would you estimate it would take the average shadetree mechanic to install this kit? Thanks for the pics!
Old Jul 5, 2006 | 07:23 AM
rygenstormlocke's Avatar
That is an impressive kit, quality looks exceptional. The option to go cowl hood and IC sounds most appealing.
14Glassback
Oct 4, 2015 08:52 AM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
