What else?
Old Sep 2, 2008 | 08:30 PM
WTCV6Stang's Avatar
What else?
So I looked on ebay an found this set up off of a GT.
http://cgi.ebay.com/ebaymotors/Parts...=p4506.c0.m245
It says it has the 2 mufflers 2 pipes,and 2 clamps. Will this work on my V6 and if so, what else will I need to make it work?
Old Sep 2, 2008 | 08:48 PM
S197 V6's Avatar
Your going to need a crossover pipe of some kind (x,h or y) and probably a hanger for the drivers side exhuast. You can find some here: http://www.v6mustangstuff.com/05V6Exhaust.htm and here http://www.ninosport.com/Mustang/Exh...4Pa38Ta38SaN10
Old Sep 3, 2008 | 07:57 PM
WTCV6Stang's Avatar
Thanks for the info! And i dont know much about pipes but the ends dont look perfecly circular(like they might be beat up a little). Would that matter when i take them to a shop?
Old Sep 3, 2008 | 09:22 PM
S197 V6's Avatar
Probably not. Most shops are very capable of bending and welding pipes, so I wouldnt worry too much about that. The hanger that I suggested you may need earlier can possibly be fabbed up by the shop, or you may try finding one on ebay, etc.
On a second note I just took a look at the link i posted up and noticed that they sell a set of hangers separetly. So like I said earlier, you will need to order that set of hangers (even though you will only use the drivers side) and a crossover pipe of your choice and then you should be good to go.
