V6 has horrible understeer!
Old Oct 30, 2006 | 05:30 PM
Little Black Pony's Avatar
I was at my club's High Performance Driving clinic this weekend and found out my V6 Pony Package Mustang understeers like a pig. I had the tire pressure set to factory specs, for the day, to see how the stock set-up will perform. Well, it performed great in most areas but when it came to turns it was horrible. It just pushed around corners because of the single track rearend. I couldn't break the rearend loose by over-reving cos the stupid slave wheel just sat there and scooted across the pavement. The drive wheel was spinning nicely though. I had the TCS turned off and we had a water truck there to wet the pavement and it still didn't help.
So I figure my options are to get a T-lok, maybe a slightly larger diameter rear swaybar and/or experiment with tire pressure to get neutral handling or more biased to slight oversteer.
Anyone else run into the understeer problem on the V6?
At least I know that the stock set-up on the V6 Mustang is great for my non-hotrod customers who want a safe vehicle. It's really hard to get the V6 into a situation where it isn't controlable. And, I tried all day. I only got it to spin once and that was cos I was on wet VHT.
Old Oct 30, 2006 | 06:36 PM
Bandit1's Avatar
I havent done alot to my stang yet,but firmer springs really helped alot in how it handles..
Old Oct 30, 2006 | 07:48 PM
WB05stang's Avatar
It's hard to get a pony package v6 into trouble. It IS not hard to get a standard V6 into trouble.
The pony package extra's make a HUGE difference in the handeling of the V6. I had a base model 05 and that car was easy to get to slide around the corners the back end of that car would slip out quite easily.
Old Oct 30, 2006 | 08:09 PM
I forgot the regular V6 doesn't have the better suspension set-up like the PP does. The GT swaybars in the PP would keep it planted better. Where as, the regular V6 only having the tiny front swaybar would have tons more body roll and weight transfer, thus creating a greater occurance of traction loss. Thanks for pointing that out.
Still need to figure out a good way to dial out some of the factory oversteer in the Pony Package.
BTW, great color combo on your Pony!
Old Oct 30, 2006 | 08:27 PM
WB05stang's Avatar
I definatly think you would want to look into stiffer springs, bigger sways and probably some better (adjustable) control arms.
The stangs are not really factory road race cars and it's definatly gonna cost..
What color are your stripes?
Old Oct 31, 2006 | 10:24 AM
Looks like the FRPP Handling pack might be in my future.
Oh, the stripes... I decided not to go with stripes, so I'm actually solid black. I need to change my avatar.
Old Oct 31, 2006 | 10:52 AM
Vermillion06's Avatar
The non-Pony Package V6's don't have a rear sway bar. Just the addition of a rear sway bar alone would really help reduce a lot of understeer.....
Old Oct 31, 2006 | 09:44 PM
Gearhead's Avatar
To reduce understeer, you need to decrease the anti-sway bar force in the front, or increase the anti-sway bar force in the rear. I find that my Eibach anti-sway bars and springs, coupled with my Truetrac, provide perfectly neutral handling. My forward anti-sway bar is on the softest of the stiffness settings (that is, the rear-most holes).
Old Nov 1, 2006 | 11:14 AM
Great feedback Brian
It confirms what I've been thinking.
Old Nov 1, 2006 | 11:46 AM
boss 244's Avatar
your best bet is to buy the gt take off front and rear bars that are offerd by diversified marketing. I got the complete pair for 89$ plus shipping. You have to buy the bolts for the rear swaybar(if you don't have a rear sway bar) from ford to make it easy. You can install them in an hour 1/2 without jacking up the car. Makes a HUGE difference.
Old Nov 1, 2006 | 11:50 AM
I-70 west's Avatar
Traction-lok rear end will definitly help, I love the improvement on accelerating out of a corner. With the X cal ll and an automatic its a riot.
boss 244's Avatar
Sorry,my sig didn't show up....
Old Nov 2, 2006 | 02:33 PM
AWmustang's Avatar
He has the Pony Package, doesn't he already have the GT front and rear bars?
Old Nov 2, 2006 | 03:45 PM
I-70 west's Avatar
YES!
Old Nov 2, 2006 | 10:33 PM
rmays06's Avatar
I haven't done to much craziness in mine but I have had no problems, hell you guys must be some good hard drivers.
Old Nov 8, 2006 | 09:27 PM
slowjoe24's Avatar
Great Info guys................thanks!! I'll be putting my front & rear GT sway bars on soon!
Old Nov 13, 2006 | 10:53 AM
boss 244's Avatar
doesn't the pony package have the gt rear and the v6 front? The gt front it much larger than the V6. I don't know, so it might be worth checking
Old Nov 13, 2006 | 12:56 PM
I-70 west's Avatar
The pony pkg gets GT front and rear bars.
Old Nov 13, 2006 | 01:23 PM
slowjoe24's Avatar
I'll give an update on the differences I felt (If any) as soon as I get them installed!!
Old Nov 19, 2006 | 08:38 PM
cookiemonster's Avatar
Ok can anyone tell me if the 2007 V6 pony package includes the sway bars? i haven't been able to get a definitive answer anywhere yet .. TIA!
