S197 V6 "Disco Potatos" Twin Turbo Project!
#81
#82
Cold Pipe complete!
Hey guys! Cold pipe is done..
Drove the car to get gas.. I didnt get on it though.. Still have several things to do... But she ran good, and maintained all fluids.. LOL!!
Here is a pic of the cold pipe.. There is only a really small area which needs to be notched to get a 3in pipe in on the drivers side.. Not a big deal..
I think my blow-off valves are leaking boost also.. I set them to the lowest spring rate for starters... However, I am pretty sure they are bleeding boost pressure before its built up...
Now that the system is together and working, I can start to make adjustments here and there..
I love the way the turbo's sound though.. They really spool rather loud..
#84
My blow-off valves were leaking boost.. I tightned them up alittle and it seems to be better.. I think I need to tighten them just alittle more and it will be perfect..
I have been up to 5-6psi however... The turbo's wooosh is pretty loud when you get off the accelerator.. LOL!!
I am so glad I went with the 6psi wastegates... They make testing a much more easier task in terms of saftey...
Those turbo's sure do get hot... I need to pickup some turbine heatshields or turbin blankets.. They are not harming anything however.. They have plenty of space around them...
I am pretty happy about everything thus far.. It seems everything is working great.. I jumped on the freeway, and this BMW was blocking me.. I wanted to get a 4th gear pull in, so I can see exactly where the boost is stopping.. I know its not going over 6psi though..
I'll keep you posted... Just letting everyone know things are going well..
I do need a good tune though.. So dont expect any numbers for awhile... But there coming dont worry.. LOL!!
#85
You're killing me without a video....
Whats up Flapjack!! I'll have to find a good Diablo tuner between here and San Francisco... If not, I may have to go SCT....
#86
I am still working on it Flapjack!! You want to know whats badazz? I took the car over a section of freeway which has a pretty steep hill.. Most cars must downshift to pull over it and maintain a good cruising speed..
Well I set the cruise control for 60mph and placed the car in 5th.. I rolled up the windows..
I listened as the car maintained a perfect 60mph and the turbo's spooled just enough to allow the car to maintain its requested speed...
I must say, the sound of the turbo spooling ever so slightly is so amazing.. Aside from racing, the turbo's really do allow the car to perform at its best.. Keep in mind I am currently running the bone stock V6 mustang tune.. However, 6psi sounds wicked in terms of turbo spooling..
Man its so awsome.. When I make a lane change, and make a pass someone on the freeway, they can hear the turbo's spool up as I pass by... LOL!!
I still in the testing phase.. I'll remain in this situation for about another 2-3 weeks.. Dialing everything in on the mechanical side of things.. I wont worry about tuning until later... I love it so far...
#87
You are running the turbos w/o any kind of fuel map?? I would imagine the Vortech tune would work better than the stock tune. You've got me worried now....
#88
The Vortech tune wouldnt work because the tune was setup so that the MAF was drawing air through a 4in pipe.. The car ran too rich with the Vortech tune and couldnt idle..
Atleast now the MAF can maintain 14.7 A/F.. At WOT it goes to the A/F commanded in the tune...
I'll get a tune later.. I still have more work to do with the system.. Atleast I can break in the turbo's for awhile...
#89
What is the commanded A/F for the stock Ford tune??
LOL! Dont worry about me...
#90
Whats up Flapjack! Actually, she's running rich.. She's dropping down to about 10.8-9 A/F...
I can get the twins to take off at about 2800RPM.. They start to scream before 3000RPM if I go WOT... I can get the wastegates to open to the spring rate which is 6psi before 3000RPM.. Which is good...
I have the car running good enough for daily use until I can get her tuned...
I had a problem running both BOV's because they were both pulling in air during vacuum off throttle situations.. With them both, the A/F would drop to 9.8 A/F... With one, it drops down to only 11.2-10.9...
Also with the car cold, with them both the car ran too rich and commanded a check engine light.. The code was banks 1 and 2 to rich...
So I will only run one BOV for now...
So yeah looks like this combo should be real good with a good tune.. Like I said, I can get them to start making boost before 3000rpm... I can build 6psi of boost before 3000RPM if I choose as well...
#94
#95
#98
Got the tune dialed in real good.. @6psi we're looking at 12.3 A/F woth about +16 degrees of timing... I could put alot more timing, but she pulls hard in all gears @ +14-16.. So I will leave it here...
I'm really impressed with how 5-6psi feels right now in 1st,2nd, and 3rd gears...
Its somewhere north of 300RWHP I am sure... I have to get used to the TQ push though... When it hits the car pulls really hard instantly and gets progressively harder as the RPM's increase... I am use to the Vortech..
I'll get used to it...
I love the sound of the blow off valve though... Guys in Honda's can't believe they heard that sound coming from a Stang.. LOL!!
I got a compliment from a guy driving a 360 Modena.. He heard the blow-off valve pop-off and through me a thumbs up.. LOL!!
