Need objective SC & IC info
Old Feb 1, 2006 | 09:12 AM
Goliath's Avatar
I've gotten the information from ProCharger, and Vortech just put their kit out, so I'll get that info once that becomes available, but I have a couple questions I need answered by parties unaffiliated with trying to sell me boost.
1st question: which is better for IC: Air to Air or Water to Air?
ProCharger claims that AtA is superior to AtW and the argument they use makes sense, but I'm not sure how much I believe em. The argument they make for AtA makes a lot of sense and I understand an AtA IC and how it could work. I'd like some thoughts from people who know and which they think is better.
2nd: Self contained or tap the oil pan?
ProCharger claims that the self contained apparatus keeps the oil much cooler since engine oil is not really cut out for SC applications.
This is something I know nothing about, so please fill me in.
and 3rd: SCT2 w/ ProCharger and Diablo w/ Vortech... yeah?
Old Feb 1, 2006 | 10:15 AM
rygenstormlocke's Avatar
My opinion, for what it's worth, I would wait a month or two to see what the Explorer Express and Powerhouse 411 offerings look like.
For your IC questions, this may help (Source: http://www.superchargersonline.com/content.asp?ID=16 )
Let's Talk Intercoolers!
8/3/2001 9:37:00 PM
An intercooler (sometimes referred to as an aftercooler) is designed to remove heat from the compressed air coming from the supecharger (or turbo) before it enters the engine's induction system. An intercooler works just lie a radiator - air is cooled by fins, bars, louvres, and plates inside the intercooler that are cooler than the compressed air coming from the supercharger. The reduction in air temperature increases the density of the air (more air molecules per cupic foot), which consequently increases your engine's ability to make more horsepower and torque. The decreased air temperature allows you to run more boost on a given octane of fuel before detonation occurs..
What's up with the terms?
The term 'intercooler' comes from days when they were first used on twin turbo aircraft engines. With two turbos, the air charge would get VERY hot - it was heated by the first turbo, then heated again by the second turbo. To combat this double temperature rise they placed a heat exchanger in between the two turbos and called it an "intercooler" because of its location in between two turbos. When this same kind of heat exchanger is used on a single turbo or supercharger, it is located after the supercharger, and should technically be called an "aftercooler" because of its location after the single turbo or supercharger. These terms didn't seem to stick, though. The term 'intercooler' caught on and became almost universal for all heat exchangers regardless of their position. The term 'aftercooler' became synonymous with air-to-water coolers because this is the term Vortech uses to describe their coolers, which are water cooled. So while technically incorrect, we will still use the popular terms 'intercooler' to mean any air-cooled charge cooler and 'aftercooler' to mean any water-cooled charge cooler.
Why Intercool?
There are several important benefits to intercooling that have resulted in their increased popularity in recent years. The most significant advantage is that intercooling increases the detonation threshhold because of the cooler air charge, meaning you can run more ignition advance for higher performance, or run lower octane fuel before experiencing detonation. This makes intercoolers very desirable for those looking to get the most out of their street vehicles on pump gasoline. The cooler air also allows your engine to run slightly cooler, reducing the chances of overheating. Intercoolers also enable your engine to produce more horsepower because of the denser air charge being delivered to the engine's combustion chamber.
Don't assume, however, that you can simply bolt an intercooler on to your supercharged engine and expect power gains with no other changes to the system. Intercoolers do create some internal drag causing a slight reduction in boost, and can also cause the engine to run lean (knock) due to the denser air charge. These problems are easily corrected and should not cause concern, however they cannot be ignored. Boost pressure can be brought back up (actually you'll probably want to run substantially more boost than you did with a non-intercooled application) using a smaller supercharger pulley. The smaller supercharger pulley will spin the supercharger faster and increase its output. Make sure your supercharger is designed to handle these higher boost levels. Correcting the air/fuel ratio to compensate for the denser air charge can be done with larger fuel injectors, recalibrated FMU, larger fuel pump, adjusting the mass air meter, etc.
Intercoolers... Aftercoolers... What's the difference?
In order for an intercooler to effectively cool the air that passes through it, the intercooler itself must be cooled by some external means. Most intercoolers are cooled just like your engine's radiator - air flows over the outside of the intercooler's fins, which in turn cool the air inside the intercooler - hence the name Air to Air Intercooler. Some intercoolers, however, are cooled by water instead of air, in which case they are generally called aftercoolers, or Air to Water Intercoolers. The benefit to an aftercooler is that air passing through it can be cooled more than in a traditional air/air intercooler if very cold water and ice are used to cool the intercooler - in fact, some aftercoolers chill the air to below ambient air temperatures even after it has been compressed by the supercharger. The reason aftercoolers are more effective in cooling the air charge is because water is a much better conductor of heat than air - in fact water conducts 4 times as much heat as air! The obvious drawback is that with time, the water will heat up to the temperature of the air passing through it, and its ability to cool incoming air goes away. Some aftercoolers, however, use a small radiator to cool the water that runs through the system, making them ideal for street use as well as racing. For drag racing applications aftercoolers packed with ice work very well because they only need to work for around ten seconds or so (hopefully) before you shut down and head to the victory podium. For milder racing and street applications air/air intercoolers or aftercoolers with radiators are more practical as their ability to cool incoming air is not reduced with time.
When is it right to intercool?
Obviously, intercoolers only work with supercharged or turbocharged vehicles where there is a substantial difference in temperature between the air entering the engine and the cooling medium (the intercooler). Because superchargers heat up the air significantly as they compress it, it is possible for there to be a very large temperature difference between the intercooler (ambient air temperature - 80F degrees or so) and the compressed air (200F - 350F degrees). Superchargers with higher boost will create a hotter discharge, so as you increase your boost, the effects of the intercooler become more and more noticable. In general we would not recommend intercoolers on supercharged engines with less than 8-9psi of boost, as the benefits will not be substantial. Essentially, run an intercooler when only when you running peak boost (i.e. any more boost would cause detonation) for the octane of fuel you use. Intercoolers work well in both warm and cool climates and work exceptionally well on marine applications because of the easy access to cold water.
Don't intercoolers restrict the flow of air into the engine?
Yes. Any time there is an obstacle in the way of the air flowing into the engine (like an intercooler fin or louvre), a pressure loss will result. Today's intercoolers are very effective in minmimzing this pressure loss so that the benefits obtained by cooling the discharge temperature normally outweigh the 1-2psi (approximate) loss in air pressure, which can be regained by running a smaller pulley and increasing the output of the supercharger.
The final word!
So while intercoolers work well on higher output superchargers, they are not recommended for lower boost level kits, like an average 6psi street kit. If you're looking for exceptional performance from your engine, consider adding an intercooler to your engine, or consider purchasing a supercharger kit that comes with an intercooler. Most ATI ProCharger systems include intercoolers and still remain very reasonably priced. Paxton has also recently introduced several intercoolers to fit their more popular supercharger systems, while Vortech already includes intercoolers with several kits. Good luck with your intercooling endeavors, wherever they may take you!
Old Feb 1, 2006 | 10:17 AM
Opps, didn't mean to copy the whole article, only the aftercooler section because I know MSP had some thoughts on considering an aftercooler. IN any case, I am sure the more knowledgeable in this area will weigh in.
Also, you might want to put this up in the other sections, I bet the GT folks can give some insight here.
Old Feb 1, 2006 | 10:39 AM
Fazm's Avatar
I emailed mike @ powerhouse, and the kit is now suppose to be available mid-end of march.
I havent heard anything from the explorer express people in a while. But if it ends up in the 3-3500 range they will steal a lot of business. (although im still most likely to choose powerhouse)
Old Feb 1, 2006 | 01:35 PM
Goliath's Avatar
the turbo still appeals to me the most, but the whine of a SC is welcomed just as easily. I've decided I'm running 9 PSI regardless what application I decide to go with. I'm favoring turbo because running sprayed is still an option once I get the internals worked out. the 4.0 SOHC tech reader from super6 was encouraging. once I get forged pistons I might even consider running 12 PSI. (and the rear end squared away)
Decisions, decisions!
Before any of this happens is a truetrac and 3.73s are getting dropped in. I'll reinforce the rear end once I get better tires, but I'm waiting till the tires need replacing before I do that.
Old Feb 1, 2006 | 02:11 PM
Thomas S's Avatar
Well as good as MSP's Vortech looks, I'm still waiting for the X-Charger and Pipeline as well. I'm leaning towards the X-Charger at this point. I can always add more NOS. I'd save about $1000 with the X-Charger and it would still go like stink on the street, and be reliable to boot. EE has a proven track record. But then if I get forged pistons.... :scratch:
Old Feb 1, 2006 | 02:18 PM
I agree, I got my Zex. I will play with that and wait to see what the market looks like.
Jul 8, 2016 08:53 AM
boz
Oct 1, 2015 04:47 PM
GLOCKer
Sep 28, 2015 05:20 PM
scott6809
Sep 12, 2015 11:44 PM
09-gt/cs
Aug 14, 2015 08:52 AM
