Installing MRT Exhaust Tips
Old Aug 17, 2005 | 08:00 AM
pony_up's Avatar
Got my MRT chrome tips yesterday and man are they sweet looking.
I need to cut the stock GT tips [they're too long] before installing and was wondering if anyone has done this mod yet? If so, what's the best approach to cutting the stock tips? Any help is greatly appreciated...
Old Aug 25, 2005 | 10:56 PM
Snets's Avatar
I just installed mine today. You have three options as far as cutting the tips:
1) Bandsaw or cutoff saw. if you have one use this first. It may require a little cleanup with a file or small drum sander.
2) Drill motor with a cutoff wheel and arbor. Keep in mind, a drill is too slow for a cutoff wheel but it will work. It will require some finish work with a grinder.
3) Cutoff wheel on a die grinder or 4" grinder. Will still require some finish work.
To mark your cut and duplicate the factory cut, wrap a folded piece of priner paper around the factory cut. Mark the inside and cut the mark. Slide it back to your desird length and trace a line on the pipe. Grind it flat. If you don't do metal work, pay someone to cut it back.
I cut mine back 1" and it looks perfect.
Ecostang
Nov 3, 2022 08:50 PM
ThatStangGuy
Jan 21, 2016 07:24 AM
tony2014mustang
Aug 9, 2015 03:04 PM
ClayP
Aug 3, 2015 09:00 PM
