Help! Installing boost gauge, ran into problem!
Old Mar 12, 2006 | 04:45 PM
flapjack's Avatar
I'm running out of ideas here.
I decided to install my boost gauge in the middle of the two center vents. I mounted the gauge no problem, and moved onto the wiring.
I located a wire going to the TCS/Hazard/Pass Air Bag cluster which was 12+ hot with the ignition switch on. I cut that wire, spliced in a new one for the gauge, wire nutted, and taped it.
Next, I did the same for the 12- going to the cigarette lighter. Before I hooked up the gauge, I turned the ignition switch on to check the wires. Nothing. The 12v I previously had was gone.
On top of that, I'm missing the four "dings" you get when you first turn the ignition on. Now, if I close the door, stick in the key, and turn the car on (w/o starting it), I get no sound. The interior lights come on and such, everything "seems" to work, I just don't have the dings and don't have 12v on that wire anymore.
I checked all the fuses and all were fine.
Any ideas????
Old Mar 12, 2006 | 05:14 PM
flapjack's Avatar
Problem found. Bad fuse.
I don't know how I missed it the first time...
Old Mar 12, 2006 | 05:28 PM
rygenstormlocke's Avatar
<div class='quotetop'>QUOTE(Flapjack @ March 12, 2006, 7:17 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I'm not surprised man, I went through 3 on this car already and a relay.
Old May 28, 2013 | 06:55 PM
Makadidle's Avatar
Any ideas????
flapjack, I have a 2007 S-197, & am installing the boost gage in the same location. wondering where you ran your line from the vac/boost source to the gage ?
Jul 8, 2016 08:53 AM
mustangsally_
Sep 18, 2015 05:35 AM
SMOKE46
Sep 6, 2015 09:40 PM
GT/CS Guy
Aug 27, 2015 07:32 PM
