Dual Exhaust Install Question...
I am taking the car in for dual GT takeoffs to be installed next week & need a VERY important question answered. I am a bit scared to do a "true" dual lset-up on the V6 as I am starting to hear hesitation on this idea. Am I better off doing a "reverse Y" setup running from the right side pipes? Looking for ANY info on this (diagrams, horror-stories, suggestions, etc.) Any help would be greatly appreciated.
Thanks,
TIM
Thanks,
TIM
Thanks,
TIM
Thanks,
TIM
Hope this helps.
Dont go the "true dual" rout. Its not worth it. You are going to lose alot of backpressure. Alot. These engines are highly dependant on backpressure for performance and.. well, you see where Im going with this. A reverse Y-pipe is the savest way to go, but alot of people have gone with Xpipes as well. I havent seen any dyno charts reflecting performance with these, but I believe they should be fairly save as well. Xpipes tend to breathe easier in the higher rpms than other midpipes, so you're going to see a gain there. The other option would be an H-pipe. You're going to get more of a classic car sound with this pipe, and see more torque gain down low rather than higher up. With X and H pipes, make sure they're placed correctly for the right savenging effect. As a general rule of thumb, the closer a midpipe is to the cats, the higher the low end torque, the farther back, the more high end. For best performance, the pipe should be placed where the gasses are the hottest between the two pipes. If the car is sitting cold, you can take a can of spray paint and lightly coat the pipes. Start the car, run it lightly and watch where the paint burns off first.. that should indicate where the pipe should be placed.
Phew, does that answer everything?
I would go the reverse- Y if you can, BUT I did end up with true duals w/ GT mufflers and if there is any loss in power I sure can't detect it. I actually requested the reverse Y when I took it in, but the shop was concerned about proximity of the crossover to the driveshaft and ran the new left pipe all the way up to the headpipe instead. So I have true duals with the factory Y acting as a crossover. Gas mileage is exactly the same, performance seems the same. It sounds good and I have two mufflers out back, that's what mattered to me
I couldn't stand one tailpipe out back.
I went with duals with an h-pipe. I have noticed some drag but I really can't be sure. I drove it into work yesterday to really give it a chance and I just really can't be sure if I've lost power. It does sound good though. Which is what I really was going for. Zodiac's post was very informative... My crossover pipe is right behind the cats. Didn't do the paint test though, just trusted the guys at the shop to do the right thing.
I've had no problems to-date with my duals and crossover setup. Sometimes I think I've lost power, other times I don't. Not much help am I?
![Icon Rolleyes](https://themustangsource.com/forums/images/smilies/icon_rolleyes.gif)
My 1st try, the mechanic cut the y-pipe and ran straight back to the mufflers - this to me is true duals. But that setup was horrible. Went to a different shop and they fixed the situation after I bought a Bassanni x-pipe. Much better. Louder, but better.
To answer your question Tim, go the reverse y route. JBA has a mac back setup using the reverse y pipe...
==Not sure I would consider your setup as true duals since you still have the y-pipe installed.==
If your definition of true duals is separate pipes on each side with no crossover, then you're right about that. What I mean was I had originally requested a reverse Y, which basically would have been a 2 into 1 into 2 exhaust setup. They ended up tying into the headpipe just past the cat, so I have duals running all the way out now. True duals with kind of a funky crossover :P
I added a custom reverse Y after the first Y pipe, Less proplems with warranty issuses later if it ever arises. Plus so far all the aftermarket duels are using Y pipes. You figure with all their time and research and that is what most are doing, I'll go with that way too....Just my 2 cents worth
