BFGoodrich Traction T/As
Yeah, looks like it might be a good choice. They have a size 235/60 R16 that should work real good on the V6 Mustang!
The Tirerack has them for only $60/tire in that size......
Kumho tire at the Tirerack
Here's the link to their Web site
Kumho Web Site
Kumho Web Site
Interior Upgrade package....
The 55 sidewall size will throw your speedometer off. Maybe go with 235/60 R16 instead?
Originally posted by dafaic@February 27, 2005, 9:16 AM
Unfourtunantly it never has clicked how the numbers work but i think the 235 makes it wider?
55 is the profile of the tire (the distance between the rim and the tread) expressed as a percentage of the tire's width. So a 235/55 tire measures about 235 x .55 = 129.25 mm from the rim to the tread.
To calculate the outside diameter of a tire you multiple the width of the tire by the profile, multiply by 2 to get both sides of the tire, convert to inches, and add the diameter of the wheel.
So the stock tire is: 215 x .65 x 2 = 279.5mm. Converted to inches this is 279.5 / 25.4 = 11.00 inches (there are 25.4 mm per inch). Add the wheel and you get 11.00 + 16.00 = 27.00 inches.
The diameter of a 235/60-16 tire is: 235 x .60 x 2 = 282.0 mm; 282.0 / 25.4 = 11.10 inches + 16.00 = 27.10 inches.
So a 235/60-16 tires makes a pretty good match for the original 215/65-16s.
235/55-16 is too small: it works out to about 26.2 inches in diameter, which is going to give you about 2 mph error at 65 mph.
Kumho Web Site
Kumho Web Site
http://forums.bradbarnett.net/index.php?sh...pic=14163&st=20
Personal Experience - I've Had Khumo tires on my cars & I've had BF Goodrich tires on my cars. I prefer the BF Goodrich. On my 05 V6, the Goodrich tires ride outstanding. I haven't spun my tires once. Breaking is excellent, and I have awesome wet traction. I live in Charleston SC, I've put nearly 10k on my car, and I've driven through a TON of rain and deep puddles (only when I have to).
The stock tires are outstanding, and while I have nothing yet to compare them against, I have found the ride to be supurb on them. They give amazing traction, handling, and control. When I'm due to replace the tires, I am considering either the white lettered goodrich's (spec/non-spec, not sure), or a set of Michelins. Always love the ride quality of Michelin tires, and since they own Goodrich, I see it as a step up.
I abhor Khumo tires. I've had 3 sets of them on 2 different cars (because of cost), and I have disliked all 3 sets. They rode rough, wet traction was apalling, and there was definately a lack of control.
That's my 2 cents. Hope it helps some. Take it for what you will - one man's testamony.
QUOTE(StangerX @ February 28, 2005, 5:55 PM)
Yes what kumhos are you talking of. I asure you they are not these. I persoanlly stand by these you can't cruise at 80 in blistering rain on just any tire with no suffering in traction. These things lay down a path and it's hard to believe the first time i noticed it i started laughing I just couldn't figure it out how a $30-$40 tire can do that when a $90 firestone couldn't. I wish i had thought of what that other guy did and trade while mine were new. I got an extra $100 laying around right now i think i am going to call the tire place and see if i can work out a deal...
Thanks for your impession of the BFG tires that come with the Mustang. I was thinking of replacing them when my car comes in, but maybe now I won't have to!
I'll at least give them a try and see?
See Rik's posts (with pictures!) in the other tire thread:
[/b][/quote]
Originally posted by bison+February 27, 2005, 10:59 PM--><div class='quotetop'>QUOTE(bison @ February 27, 2005, 10:59 PM)</div><div class='quotemain'><!--QuoteBegin-Falchion@February 27, 2005, 9:18 AM
Kumho Web Site
Kumho Web Site
[/b][/quote]
For what kind of tire? Make/model/size?
That size would be almost the same as stock for your speedo!
That might be a good way to go for somebody who doesn't like the stock tires.
Here's a link to a tire size calulator to compare sizes.....
Tire Calulator
Tire Calulator
9/8/15 10:45 AM
