Air Tube
Air Tube
Is there an after market replacement air tube for the stock airbox and throttle body? I`m wanting a aluminium or stainless steel unit for improve air flow over the rubber OEM piece.
Justin at VMP has tested the V6 pretty extensively and found the V6 stock inlet tube is not what is restrictive. The intake he sells doesn't replace the stock tube, so I'm not sure you would see much of a gain with a high-flow tube. It would look a heck of a lot better though.
Antigini-GT/CS
10/5/15 09:43 AM
