3.5 V-6 ?
Old Sep 30, 2005 | 09:44 PM
79cobra's Avatar
At the risk of sounding ignorant there used to be some discussion on a new 3.5L V-6 coming out for the Mustang with 250ish HP. Since this is the most reliable source for info I was wondering if there has been any more news on that ??? :scratch:
Thanks for the info
(been looking for a thread, hope I didnt miss it)
Old Sep 30, 2005 | 10:52 PM
Fazm's Avatar
im pretty sure we all came to agreement, that it doesnt make sense for ford to go through all the work of planting a 4.0 in there, just to change it to a 3.5 in a couple years. And although the 3.5 has much more HP, its lackin in the torque area, which is what most people enjoy.
Old Oct 1, 2005 | 02:35 PM
esorense's Avatar
Thumbs down
The bottom of this post has some background links on this motor. It will be built in Lima, OH. It will feature an aluminum block built by Teskid in Alabama. This is good for us Mustang folks as that would mean weight savings in the V6. It features variable valve timing -- good for Vitamin H AND fuel economy. These pictures show the engine with a VERY low oil sump. That IMHO is BAD for us Mustang folks as that means the engine would have to be mounted higher in the engine bay and they likely could not fit the car with the long runner intake manifold that they did on the Mustang. Plus you'd have to forget about suspension lowering, etc. That would mean the V6 mustang would loose its signatrue throaty growl (yes, long intake runners on the intake manifold means sweeter sounding exhaust) and likely have ill effects on handling. The current Ford V6 Mustang 05+ is a true 'sleeper' car. The took the same base engine found in Ford Exploders and Rangers & fitted it w/ long runner intake manifolds (hence why strut tower braces are so tough to fit on this car) and special exhaust manifold headers unique to the motors fitted in the 'Stang.
With this 3.5 engine, in its current form, the V6 Mustang would go back to sounding like a typical fleet-rental car or mommy-van grocery getter. Those types of vehicles would benefit from the new Duratec 3.5 as the buyers of those cars don't care about the things that Mustang owners care about. If you read through the links you see that the engine can be safely bored out to 3.8 liters -- which is pro-mustang. But, the overall design of the motor seems anti-mustang due to low oil sump and wimpy corporate V6 exhaust. NONE of the articles confirm/deny/speculate on fitting of this motor to the 'Stang. Duratec = Ford Corporate fleet V6. I'd cringe if the put a Duratec in the 'Stang. The truck-based 4.0 is more of a gearhead motor.
With Fords migration and investment in Lima, I have not yet heard of any plans to simultaniously mothball their Cologne, Germany engine plant where the 4.0 is produced for the 'Stang, Exploder, Ranger, et.al.
http://www.conway.com/ssinsider/bbdeal/bd030721.htm
http://www.findarticles.com/p/articles/mi_...83/ai_106733147
http://www.findarticles.com/p/articles/mi_...39/ai_107473854
http://www.jwfisher.com/sec-ford/FMC-engin...35d/default.htm
History of Duratec family -- 3.5 info is on bottom
http://www.madabout-kitcars.com/kitcar/kb.php?aid=32
Old Oct 1, 2005 | 02:38 PM
esorense's Avatar
Dittos. Lets hope Ford does not awash the sweet car the V6 is w/ some dumb-numb coporate mill.
Old Oct 1, 2005 | 05:20 PM
TJ06's Avatar
esorense Nice post you have given all the pros and cons very good post thanks.
Old Oct 1, 2005 | 08:13 PM
ManEHawke's Avatar
The 4.0 offeres a great baseline for those who would love to mod.
Thats a great post Eric, I agree that we have a great sounding V6. I wouldn't give that up for 40hp and what seems to be a less torquier engine. It is a great powerplant, but I also don't think its Mustang material.
I feel, once aftermarket catches up some more, we will have a really satisfying V6. And one that provides some fun, and enjoyment to rod it out. At least Ford gave little thought to the V6 and not sacrifice a bit of that Mustang flavor.
Old Oct 2, 2005 | 12:15 AM
1trickpony's Avatar
I saw something over at Blueoval News. It showed the phase in of the 3.5 over the next 4 years or so. The Mustang was not even listed so I wouldn't expect to see it in the Stang. It would drive up the base price, probably over $1,000. The 4.0 would offer equal or better performance until 5000 rpm or so. I doubt the 3.5 would offer much better straight line performance. With the extra cams and tech the 3.5 will probably weigh about as much as the 4.0. The 4.6 V-8 only saved about 65 lbs with an aluminum block. The only real advantage I see with the 3.5 is NVH, it will be smoother or more refined.
Old Oct 30, 2005 | 04:03 PM
esorense's Avatar
Red face
The 4.0 engine will also be the base for the unofficially announced Shelby V6. See other threads for that. Its possible to supercharge the 4.0 engine to some pretty incredible levels (search yet for other threads on that - covered @ extreme length elsewhere) & the 4.0 motor has a lot more mod potential than the 3.5 IMHO. The V6 4.0 is here to stay likely through 2009.
Old Nov 1, 2005 | 11:16 PM
79cobra's Avatar
Thanks for the info, I knew I could count on you guys!
Old Nov 9, 2005 | 03:51 PM
esorense's Avatar
New Link --
http://media.ford.com/article_display.cfm?...4&make_id=trust
Old Nov 9, 2005 | 07:07 PM
Zodiac's Avatar
Quoting the above article...
"The engine produces 250 horsepower and 240 pound-feet of torque in its CUV applications. It uses a dual-overhead cam valvetrain for peak power capability and smooth operation at high RPM. It incorporates intake variable cam timing to optimize fuel economy by adjusting valve timing for a smooth idle, optimal part-load driving and an impressively broad torque curve with good power. "
"Ford ... delivering on its commitment of putting 250,000 hybrid vehicles a year on the road by 2010"
Link to tech specs:
http://media.ford.com/article_displa...ticle_id=21987
Its gonna be interesting to see if they ever look to the Mustang for application of these new engines / 6-speeds.
Ecostang
Nov 3, 2022 08:50 PM
Detroit Steel
Jan 17, 2016 08:06 AM
mx5jhb
Sep 30, 2015 04:44 PM
Evil_Capri
Aug 27, 2015 01:08 PM
FarmAnimal
Aug 3, 2015 05:53 PM
