x pipe with no tune .
Old Mar 22, 2005 | 10:42 AM
porsche's Avatar
after installing xpipe with no tune it made 8rwh and it goes lean to 13.7.
also for kicks then i put on a c@l intake with no tune and could not finish my dyno run. goes way to lean. so make sure you tune before driving around with bolt on parts.
Old Mar 22, 2005 | 10:48 AM
HOTLAP's Avatar
Porsche - what x-pipe did you install, and does it have the high flow cats or no cats? Did you install just the x-pipe or a cat back/axel back system as well? Just curious as Magnaflow has stated up to 19rwhp with no tune(combined with the Magnaflow cat back exhaust)....by the way - thanks for the data - I suspected that adding less restrictive exhaust would make the engine run lean despite claims that changing exhaust doesn't add much or require a tune. Appears that the intake side is more critical - but still the exhaust side does need to be taken into account for accurate tuning.......I'm a bit confused as to how tuners can claim that a single pre-made tune can cover a variety of mods......really hits home that a trip to the Tuner shop is required if you have multiple mods, i.e., intake and exhaust sides.
Old Mar 22, 2005 | 10:51 AM
porsche's Avatar
bassani hi flow cats with x pipe .
Old Mar 22, 2005 | 10:55 AM
HOTLAP's Avatar
Stock mufflers?
Old Mar 22, 2005 | 11:06 AM
porsche's Avatar
all stock just x pipe hi flows. I was having a cel problem and had a night to kill at a friends dyno so i put back to stock and started over . steeda pullies 4 hp over x pipe dyno. so now it is up to 285 at this point with no tune. Now this is strange my all time high is like 292 rwh with a c@l and tune .So this weekend i will try a 91 and 93 tune and then the c@l tune with intake . I had problems downloading the new tunes last weekend .But no cel lights.
Old Mar 22, 2005 | 05:30 PM
HOTLAP's Avatar
Rough life Porsche.....had time to kill at a friend's dyno shop WOW - I've got a couple of friends with pretty cool gas grills - but no dynos
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
Sep 24, 2015 08:15 PM
