Will this work on 17" premium rims?
Old Nov 17, 2008 | 04:15 PM
The Reverend's Avatar
Hello,
Local deal I am looking at for $150. 6k miles of use, 85% thread left????
I would install on 17" premium rims.
275/40/R17 Mickey Thompson ET Street Radials
Old Nov 17, 2008 | 04:49 PM
70MACH1OWNER's Avatar
Seems to wide to me. It has been pretty much accepted that 255's is as wide as you can "safely" go with. I am running 275's Nitto's on 9.5 wide rims and that looks right.
Old Nov 18, 2008 | 07:09 AM
69Mach1-409's Avatar
Are you going to be using them just for racing or DD'n too?
I was told they would be fine for drag race duty and have been trying to find a cheap set of OEM 17's for that exact tire.
Old Nov 18, 2008 | 07:36 AM
Only driving to and from the track and drag racing. I have four 17" premium rims, two for those two tires. Do you care to purchase the other two?
Old Nov 18, 2008 | 04:18 PM
tom281's Avatar
For those purposes, you should be OK. I'd say they're too wide for normal street driving, but I've seen those tires on stock wheels lots of times. Heck, that's the combo of choice at Brenspeed for budget racing. Check it out here:
http://www.brenspeed.com/charcoaldragpack.html
Old Nov 18, 2008 | 04:19 PM
ok, thanks, someone beat me to it. But I will get some new ones, thanks again. At least I sold two of my rims, and can now buy new tires.
Old Nov 19, 2008 | 01:25 PM
Thanks!
Old Nov 19, 2008 | 10:17 PM
don_w's Avatar
FWIW, a lot of guys run the 275/40 on an 8" wheel, but they fit better on a 9". The best DR I know for the 17x8 is the 275/50-15 M&H. They aren't a true 275 (8.8" tread width), so they work great on an 8" wheel. BUT... they are 28" tall, so you probably want 4.10s back there.
And for the record, I call on the above. After 6k miles, you'd be lucky to have 40% tread left, and that's only if they never had any burnouts.
Old Nov 19, 2008 | 10:20 PM
DKO's Avatar
DKO
They will work fine for your intended purpose. I ran 275s on my old cobra which was 17x8 and DD'd it. They will bulge a bit, but for a drag radial it's perfectly acceptable.
Ecostang
Nov 3, 2022 08:50 PM
Jul 20, 2015 06:26 AM
whowasthat
Jul 19, 2015 01:49 PM
