Will fresh plugs lean out my motor?
Old Jun 29, 2007 | 08:55 AM
Bullitt995's Avatar
I'm going to change out my plugs tonight to try and recover some of my lost horsepower. Will this cause the car to go lean? I'm worried because I'm running nitrous and lean + nitrous = very bad.
Old Jun 29, 2007 | 09:05 AM
theedge67's Avatar
I do not see how it would make the car run lean at all. Plugs wouldn't affect that.
Old Jun 29, 2007 | 09:19 AM
Bullitt995's Avatar
Thought maybe they would burn the gasoline more effectively causing it to go lean. Maybe I'm just worrying too much.
Old Jun 29, 2007 | 02:48 PM
kevinb120's Avatar
do you have like 80k miles on it or something??
Old Jun 29, 2007 | 08:41 PM
TillmanSpeed's Avatar
Former Vendor
Are you using the same heat range plug?
Old Jun 29, 2007 | 08:45 PM
MrClean's Avatar
CR: PM sent
Old Jun 29, 2007 | 09:39 PM
65sohc's Avatar
Plugs won't change AFR. The issue with running nitrous is higher combustion chamber temps and pressure leading to detonation. With any big time power adder you should run colder plugs which are less prone to detonation. The downside of colder plugs is a higher tendency to carbon foul during normal driving.
Old Jun 29, 2007 | 10:05 PM
Bullitt995's Avatar
No it's stage colder.
Old Jun 30, 2007 | 09:13 AM
RadBOSS's Avatar
lean has to do with too much oxygen / not enough fuel
with nitrous, if you do not add enough fuel, that will be lean.
Old Jun 30, 2007 | 12:28 PM
Former Vendor
As long as you're using a colder plug, the efficiency of the new spark plugs will not have any affect on the AFR.
Old Jun 30, 2007 | 12:32 PM
MrClean's Avatar
CR: Pls read your PM. Also left you 2 voicemails at the office...
Old Jun 30, 2007 | 02:08 PM
ren274u's Avatar
since were talking about plugs, i wanna change the stock ones out, if i got one colder will i have any issues being n/a and my daily driver?
Old Jun 30, 2007 | 03:06 PM
Bullitt995's Avatar
Thanks. I pulled the plugs and I found the issue. I'm making another thread in a sec.
Old Jun 30, 2007 | 03:55 PM
goldenpony's Avatar
Plugs
In answer to your original question-no.
Old Jun 30, 2007 | 05:38 PM
RadBOSS's Avatar
It might be. Under street driving conditions, cold plugs can load up. For street driving you are better off with the recommended heat range.
Old Jul 2, 2007 | 09:56 AM
Sharky's Avatar
Just drive it like you stole it and you'll have no problems with one range colder.
Old Jul 2, 2007 | 10:01 AM
Bullitt995's Avatar
Here's what the plugs looked like:
Hmmmmm
I also want to clear up a little confusion. The plugs are the same heat range as before but they are a step colder than stock.
Old Jul 2, 2007 | 11:38 AM
don_w's Avatar
FWIW, I ran the same set of HT1 plugs for 10 months, 13,000 miles and well over 500 runs, without a single issue. A couple weeks ago, the HT1s were replaced with a new set of HT0s, and they lasted exactly one day (4 runs at the track, and less than 200 street miles). I immediately replaced them with a new set of HT1s again, and everything seems fine again.
Just my experience...
Old Jul 2, 2007 | 11:58 AM
Bullitt995's Avatar
HT1 heat range plugs don't like nitrous one bit. Here's a pic of 2 of the stock heat range plugs after a bottle or two through them:
Old Jul 2, 2007 | 08:28 PM
psfracer's Avatar
What gas are you using?
What is your a/f ratio?
What is your total timing?
Better be careful, do that to often and your going to hurt a piston.
