Wierd Clanking Noises
Old Oct 5, 2010 | 10:11 PM
d_bone33's Avatar
Ok, so i lowered my car before i deployed, and since i lowered it, everytime i pass over a decent bump on the right side i get a clunking sound....almost like a shock/strut problem. I have replaced the front shock with a the Tokico shocks. I have also replaced the caster/cambor plates. I dont know what else to do...or what the noise is. I have taken the tires off and check everything, i thought it might be the front sway bar rattling. I have checked that and everything i could think of to see if it was loose. Does anyone know what this noise could be. Also.............towards the rear of the car when i go over the same bump on the same side. I get a metal rattling sound like metal on metal sounding when i go over the same bump. It clunks in the front of the car and a wierd eeeerrrrkkkk errrrkkkk sound towards the rear of the car. It is really pissing me off and fustrating...someone please shine some light on this for me. I have no idea what to do. I even took it to an alignment shop and had them check the suspension for anything loose or wrong, and they say everything is fine.
Old Oct 6, 2010 | 05:33 AM
05YellowGT's Avatar
Do you still have the OEM upper strut mounts ? There are a lot of threads on here about this causing a clunking sound. Here's a link to the Steeda ones I got ...
http://www.steeda.com/store/ford-mustang-springs.html
Old Oct 8, 2010 | 08:28 AM
jlmounce's Avatar
CHeck the torque and install on the panhard bar in the rear.
My stock panhard bar is making about the same noise you describe. I'm about 95% sure it's the culprit. I got under the car and tugged, pulled, banged the bar and I could pretty accurately reproduce that sound.
Old Oct 9, 2010 | 02:10 PM
d_bone33's Avatar
I have JDM i believe castor/cambor plates up top where the OEM strut mounts where at..i know you can reuse the OEM ones..or its highly un prefered....Also about the Panhard bar, i have an Steeda adjustable one sitting in my garage that i need to put on. I need to check what you said, cause about a year ago i was going to put the steeda one on, and i took the old one off, then i realized i didnt have wrenches big enough at the time so i put the OEM one back on....all in all, my car sounds like its falling apart, it looks so nice, and i have so much money in it, and if you hit bumps it just sounds like a clunker lol, i hate it
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Mr. V
Dec 24, 2016 02:57 PM
ricky1728
Feb 11, 2016 07:25 PM
Rando
Sep 30, 2015 12:28 PM
