Why is my car not making power?
Old Apr 21, 2007 | 10:32 PM
Bullitt995's Avatar
Well today we tried again to get my car to make the correct power numbers but it just won't budge. It made like 285/297 off the nitrous and 350/405 on a 100 shot with these mods:
NX Wet Kit - 100 shot
KB boost-a-pump (complete trash)
Autolite HT0 plugs
C&L race intake
Hooker LT headers
Hooker O/R x-pipe
Magnapacks
Centerforce clutch
Pro 5.0 short throw shifter
BMR lowering springs
BMR lower control arms
BMR panhard rod
Thinking maybe the intake is too large mm for the power mods?
Old Apr 21, 2007 | 10:42 PM
dustindu4's Avatar
9 is not my lucky number.
your numbers look right to me
Old Apr 21, 2007 | 10:45 PM
Bullitt995's Avatar
Yeah except it made 290/301 and 386/432 without the headers, o/r x, and a K&N instead of the C&L.
Old Apr 21, 2007 | 10:49 PM
ov3n's Avatar
Is it properly tuned with an Xcal2 or Diablo predator tuner?
Old Apr 21, 2007 | 10:51 PM
Bullitt995's Avatar
Yep, custom tuned by Doug himself.
Old Apr 21, 2007 | 11:56 PM
Error404's Avatar
Are you are referring to the 100 shot not making you 100 extra hp? That might be normal.
Old Apr 22, 2007 | 12:18 AM
Bullitt995's Avatar
Nah I know that's normal. I'm talking about me loosing 5rwhp from LT headers, o/r x-pipe, and a better intake.
Old Apr 22, 2007 | 05:33 AM
tom281's Avatar
1) Your before/after numbers are from the same dyno, correct?
2) When you say "custom tuned by Doug"- did he actually tune the car on a dyno or did he just send you a tune for the mods you have?
3) Are you running a different tune when you run the nitrous? As in, do you run a tune for normal driving, and then change tunes when you want to spray?
It seems to me that the only way you would "lose" power by adding headers and o/r exhaust would be if the tune isn't right for those mods. Or, if your running one tune only for both n/a and spray, maybe it is pulling too much timing when you're running just n/a.
Also just curious- why do you think the KB BAP is "complete trash"???
Old Apr 22, 2007 | 12:13 PM
Bullitt995's Avatar
1) It's not the same dyno but they are both dynojets. Could the calibration be that different?
2) I drive up to Birmingham to have Doug tune it in person. The new and the old tunes were both done by him.
3) Yes it's a different tune as in timing is pulled but all the a/f adjustment is done through fuel jets. Doug was also double checking everything on both tunes.
We determined the boost-a-pump was worthless while tuning for the nitrous. It did exactly the opposite of what it was supposed to do. Made it go way lean immediatly when it's turned on and we sprayed.
My two guesses were the intake might be too much and the dyno was just different. I meant to see what the close to stock 07 GT made yesterday but I left and I forgot about it and left.
Old Apr 22, 2007 | 03:29 PM
DynamicmustangGT's Avatar
yeah i would expect the headers and x to add 25-30hp and similar ft lbs
Old Apr 22, 2007 | 03:36 PM
boss429man's Avatar
JMO, your car seems like it may be running lean what size injecters do you have?
Old Apr 22, 2007 | 05:29 PM
Bullitt995's Avatar
Stockers but the a/f was dead on.
Old Apr 22, 2007 | 09:32 PM
according to my calculations you should be making around 310-320rwhp and you are failing short. I say return to stock and retune your car to stock. Then put evrything back on and retune unless your dyno guys want to try something.
Old Apr 22, 2007 | 09:55 PM
Bullitt995's Avatar
I'm gonna get it on a different dyno first.
Old Apr 22, 2007 | 10:00 PM
yeah, that might be it. I meant if you can't free up that power than try and see if stock it ok. If not you probably messed something up.
Old Apr 23, 2007 | 09:13 AM
05-1947's Avatar
Have you added gears since the previous dyno? I has been known that gears may show a loss on the dyno.
Old Apr 23, 2007 | 09:28 AM
Rondosa's Avatar
Meet Krissy, Our Star Racer
Hahah dude, easier said then done. Have you ever installed LT headers...I've only helped on a '99 GT but it's not exactly a 2 minute job!
Good luck Bullitt995, hopefully you can get your numbers up...
Old Apr 23, 2007 | 10:10 AM
Bullitt995's Avatar
Nope.
Old Apr 23, 2007 | 11:04 AM
futuresvt's Avatar
I was at a charity Dyno day this weekend and my bone stock (engine at least) 07 GT put down right about 276/297 to the rears on all 3 pulls...FWIW
good luck
Old Apr 23, 2007 | 03:29 PM
Bullitt995's Avatar
good luck
I meant on the same dyno I used so I could see if it made lower than normal numbers also.
