Why did Ford use a steel driveshaft?
Old Oct 25, 2006 | 07:12 AM
metroplex's Avatar
Why did Ford use a steel driveshaft on the S197 GT instead of aluminum or an aluminum metal matrix composite material?
Old Oct 25, 2006 | 07:23 AM
SteelTownStang's Avatar
Old Oct 25, 2006 | 07:42 AM
Louie's Avatar
Originally Posted by SteelTownStang
+1
The stock driveshaft performs great and gets the job done.
For an aftermarket Al piece you must pay around $700. Would you have happily paid that much extra if it were OEM?
Of course, if you're planning to add a supercharger, then it would be wise (yet still not absolutely necessary) to install an Al driveshaft.
Old Oct 25, 2006 | 08:02 AM
metroplex's Avatar
Originally Posted by Louie
+1
I would have happily paid extra for factory installed options such as:
AMMX driveshaft ($700 not a big deal)
3.73s Limited Slip ($200-$300, no biggie)
cold air intake ($300+, with factory warranty)
suspension upgrade package ($??, still good w/ factory warranty)
MyColor and trip Computer separate from IUP
2-tone interior separate from SAP
instead of 3-5 different appearance/interior trim packages that do not add any performance/handling value to the car, other than tack on useless body effects and chrome "burn your skin in the summer" trinkets/panels for the interior.
Old Oct 25, 2006 | 08:06 AM
Louie's Avatar
Well, you do have a good point there, but I don't think the majority of Mustang buyers absolutely wanted an Al driveshaft. Like I said, it all comes down to cost cutting.
We're lucky to have such a rich aftermarket offer, though!
Galaxie's Avatar
I Have Admin Envy
There are lots of us here that would pay more for higher end things. The problem is they want to keep as minimal of build combinations as possible.
The aluminum driveshaft is a good ideal that they may have been able to save money on for example. Instead of the 2-piece steel shaft with a U-joint, they could have probably had a one-piece aluminum shaft. I'm sure the cost of the shaft would have offset the cost of the extra C-V joint.
I would have loved IRS being an option, ditto for upgraded interior bits that only now have showed up.
Old Oct 25, 2006 | 08:58 AM
94tbird's Avatar
actually the steel 2 piece was used to absorb vibration and road noise to keep it out of the cabin. this is why they used rubber busings on the LCA's, UCA, panhard bar, and almost everywhere else you can see. Deadens the road noise. Change to an aftermarket suspension like me with poly urethane bushings and see how the noises will annoy the hell out of you. i wish i had the quiet ride i had before with the performance handling i have now.
Old Oct 25, 2006 | 11:53 AM
RKNMACH's Avatar
Good point. The ground noise is my only disappointment with the car. Still waiting to hear about any Dynamat installations.
Old Oct 25, 2006 | 01:58 PM
lodom's Avatar
There are some comments about the sonic improvemets of adding dynamat in the trunk/rear deck area if you do a search. They used to be confined int the interior/audio forum.
Old Oct 25, 2006 | 02:11 PM
metroplex's Avatar
Do you know where the dynamat should be installed?
Trunk floor, sides, trunk lid, etc...
Old Oct 25, 2006 | 02:15 PM
RKNMACH's Avatar
I'm looking at the trunk area only. A S/C V-6 owner posted he was going to do some Dynamat work and I'm waiting for his feedback. Just trying to cut out a bit of the drone and tunnel noise.
Old Oct 25, 2006 | 02:31 PM
metroplex's Avatar
I meant, what parts of the trunk should be dynomat'd?
Old Oct 25, 2006 | 02:38 PM
Vermillion06's Avatar
To the vast majority of car buyers (i.e. casual Mustang fans, not the hardcore types like you and me ) appearance options are important than parts that cannot be seen but actually do something besides look good.
Mustang fans are very fortunate that there is a entire cottage industry built around the Mustang, and aftermarket parts are readily available. Support the economy! Add aftermarket parts to your Mustang!
Old Oct 25, 2006 | 03:02 PM
RKNMACH's Avatar
I'm going to start with the trunk floor - try and deaden some of the exhaust noise. Hopefully I won't have to take out the rears seats. I like the sound of my exhaust but would like it a little quieter inside.
Old Oct 25, 2006 | 03:22 PM
Dysan's Avatar
Depends on what you are trying to accomplish....If you are only trying to get rid of road noise(not trying to help with a stereo install) then the bottom and sides of the trunk. If you are working for a stereo install, you'll want to also do under the rear deck and the trunk lid as well. With sound dampening materials, more is better so if you can afford to give it 2 layers, that will help even more. I did most of my trunk, and I also did the inside floor and under the console and it helped quite a bit. Doing the console also helped to greatly reduce the extra noise from my aftermarket shifter.
Old Oct 25, 2006 | 03:24 PM
RKNMACH's Avatar
What type of product did you use on your trunk? No stereo for me, just a little bit of quiet.
Old Oct 25, 2006 | 05:44 PM
GT John's Avatar
So far I have installed dynomat in the trunk and trunk outer skin, covered all exposed metal, even behind the rear plastic stuff (back license plate area). And also installed a few strips up where the rear speakers are.
Have installed Dynomat in the rear seat area + rear floor (you have to remove the rear seat) all exposed metal.
Have installed Dynomat in both doors, once again all exposed metal.
Havent got around to doing the front floor board or firewall yet.
It takes a lot of work and it aint cheap. But its really worth it.
Give it a shot. Do the trunk area first just so you'll see that your not wasting your time.
Old Oct 25, 2006 | 11:12 PM
Mongoose's Avatar
Why don't you write Ford and ask them?
Old Oct 26, 2006 | 06:54 AM
RKNMACH's Avatar
What package did you order for the trunk? Do you need the roller they show on their web site or can you mold the Dynamat to trunk floor etc w/o any problems? Thanks.
Old Oct 26, 2006 | 09:59 AM
dustindu4's Avatar
9 is not my lucky number.
This is all true. Plus they can hit you up for another $300 FRPP alum driveshaft later on.
Makes me laugh when people complain about their Mustang being noisy, when I can't even have a conversation inside the car with the windows rolled up.
Ecostang
Nov 3, 2022 08:50 PM
iceD
Apr 10, 2016 12:59 PM
JonathonK
GT350
Sep 17, 2015 10:13 AM
