Whistle sound at 4k rpm?
I have the same whistle sound once I installed a K&N filter as the new filter draws more air into the engine than the factory filter. If you have changed the filter system then this could be the reason for the whistle.
Any of you guys have radar detectors??? Cause I noticed this problem and I discovered the "drill" high whisling noise It was my radar detector making tha whistling noise. Apparently, the radar detector was picking up the RPM range noise and somehow, I don't know electronics, everytime it goes up higher in the RPM range, you hear this tiny electrical whislte "drill" noise. That could be the problem, but I turned down the volume **** just a tad, problem solved!
Rando
Aug 25, 2021 11:12 AM
