where to hook up my new shift light?
Old Dec 8, 2007 | 06:44 AM
91svtcoupe's Avatar
I just bought this shift light http://cgi.ebay.com/ebaymotors/ws/eB...181268376&rd=1
and was wandering where the best place to hook it into.....Taco went with the #8 coil pack I think? is this the best place? Thanks Rob
Old Dec 8, 2007 | 07:24 AM
tom281's Avatar
That's where I got mine.
Old Dec 8, 2007 | 04:49 PM
07Foose's Avatar
Link doesnt work
Old Dec 9, 2007 | 11:21 PM
281GT's Avatar
Any coil will give you the correct signal. For my homemade shift light I used this and it works well.
Number eight works well because it's next to the firewall and makes it easy to run the wire inside the car.
The coil has two wires, make sure that you tie into the signal wire and not the ground.
Use a VOM (volt / ohm meter) to determine which wire is correct. Set your meter to any resistance scale, ground one side of the meter, connect the other to one side of the coil. When you get conductivity you know that the other wire is what you need as a signal for your shift light.
Old Dec 12, 2007 | 08:02 PM
91svtcoupe's Avatar
got it
Alright....I got my shift light in today looks very nice...I am going to use the add a cirucuit to the fuse box and I could not even get the fuse box cover off......WTC! I guess I will have to take the whole kick panel off..Got the ground hooked up and I am looking to put the green signal wire through the rubber groument. I have it started....but can't see it coming through in the engine compartment? Do I need to take the inner fender out? or just try and see the wire coming through? I figure from reading it will be best to hook into the white wire with a red stripe. Any long term affects of this? why on some old post were guys having such a diffucult time with shift lights? Thanks again Rob
Old Jan 8, 2012 | 09:06 PM
fic's Avatar
fic
can any one tell me why my shift light wont come on ?At the rpm i want.It only comes on around 1oo5 rpm i have it set for 3000rpm.I ran my green wier to coil pack driver side the closet 2 fire wall.I used the red wight weir off the coil pack .I ran red + weir stright to batterie and my neg-- is grounded. could it be that the wiers i used are biger than the ones on shift light. giving me a ****y signal. And is taping into my coil pack going to efect my car pleas help me any body i dont want t mees up my car
Old Oct 26, 2013 | 05:34 AM
Mike James's Avatar
shift light
hello mustang friends, can you please tell me what shift light you all used ? the link is bad now, and i am interested in installing one bad in my car.. and can you put in a picture how you mounted it? thanks,
14Glassback
Sep 11, 2015 04:50 PM
