Wheel Hop
Old Oct 18, 2007 | 09:24 AM
302svt's Avatar
Wheel Hop
What is the best way to go about getting rid of wheel hop. I have heard that you just needed an UCA and then I heard you just need the LCA's. My car isn't lowered and will not be and I am trying to get away from adjusting the pinon angle if I can. Also what brand would you recommend.
Old Oct 18, 2007 | 09:29 AM
scramblr's Avatar
Solid LCAs will do the trick. BMR or CHE. If it's still present, you can do a solid UCA as well, but chances are you won't need it. Here's a write up on LCAs.
http://www.2005stang.com/gallery/alb...%20install.doc
Old Oct 18, 2007 | 10:27 AM
Keystone's Avatar
Just the LCAs did the trick for me at first, but when I switched to a wider rear tire I got a little of the hop back. Replacing the UCA has cured it for good.
Old Oct 18, 2007 | 10:29 AM
302svt's Avatar
When you replaced the UCA did you go with the adjustable or not. Also did you have to set your pinion angle.
Old Oct 19, 2007 | 01:59 PM
freebass55's Avatar
LCA's did not get rid of my wheel hop. I remember reading that the UCA will get rid of all wheel hop. LCA's will help, but do both and be done with it.
Old Oct 19, 2007 | 08:31 PM
AGBULLIT's Avatar
What about Steeda's Stop the Hop Pak?
http://www.steeda.com/products/stop_the_hop_s197.php
Old Oct 19, 2007 | 11:31 PM
scramblr's Avatar
You can get BMRs for less than $270.
Old Oct 20, 2007 | 03:32 AM
SurfNut's Avatar
Stop the Hop
I've got that on mine. Works great.
Old Oct 20, 2007 | 06:51 AM
07VistaGT's Avatar
I installed the steeda LCA's and that did away with 90% of the wheel hop
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
