Whats the trick to chirping tires in second?
Old Jun 26, 2007 | 08:06 PM
VVVROOM's Avatar
OK...kind of a noob question, but I got to ask.
Whats the trick to chirping the tires in 2nd gear? I have a manual trans with JLT 2 CAI, 93 octane torque tune (tillmanspeed), and I've tried several times...WOT in first gear up to 6K RPMs, but the shift to second gear is not very satifying . The car takes off like fast, but thats about it.
Perhaps I need the tune adjusted, or maybe its the driver
Old Jun 26, 2007 | 08:08 PM
AFChief's Avatar
TCS off?
Old Jun 26, 2007 | 08:11 PM
tom281's Avatar
Quick, clean, and precise shifts. Practice makes perfect......
DarkFireGT's Avatar
Turn TCS off. Even with my sticky BFG's I can squeal 2nd and chirp third. I haven't tried 4th, I run out of road. On stock tires you should be able to fry them through 2nd even bone stock if you power shift.
Old Jun 26, 2007 | 08:12 PM
VVVROOM's Avatar
Originally Posted by AFChief
TCS off?
Yup...TCS was disabled in my custom tune.
Old Jun 26, 2007 | 08:14 PM
Thomas S's Avatar
**** man, my car barks the tires going into 2nd, 3rd and 4th. Even with the TCS on. But I have an auto with a BamaChips tune.
Old Jun 26, 2007 | 08:17 PM
JonCo's Avatar
I can chirp 2nd fairly easy and 3rd every once an awhile but have never heard or thought about 4th... Something to shoot for, hah
Old Jun 26, 2007 | 08:22 PM
don_w's Avatar
If all else fails, find a really smooth road that runs uphill.
RadBOSS's Avatar
Tom281 is right.
Mine is totally stock and I have gotten more than a chirp out of it with rear axle drifting sideways just a touch ... and with traction control on. The shift only needs to be fast ... not brutal. Not a true powershift but carrying some RPM's at clutch engagement and lots of throttle as you quickly release (not pop) the clutch.
Old Jun 26, 2007 | 08:23 PM
svt boost's Avatar
supercharge it...
tom281's Avatar
ttbit's Avatar
It's all timing. If you force it, you are going to rag the tranny. In stock form with the TCS off you should be able to get major scratch in 2nd and a good bark from 3rd, which is nothing impressive. I could do it in my friends '8x Chevette with 4 people in the car. All a matter of how much you respect the car and nothing about how quick it is. You may be doing just fine without getting scratch.
Old Jun 26, 2007 | 08:30 PM
procopius's Avatar
I have no trouble squawking into 2nd and chirping into 3rd, TCS on, bone stock. TCS does prevent basically any wheel spin in 1st for me though. Shifting about 5500-6000rpm. There's no trick really, I usually don't even give it WOT.
Old Jun 26, 2007 | 08:31 PM
1200custom's Avatar
Originally Posted by RadBOSS
Tom281 is right.
Mine is totally stock and I have gotten more than a chirp out of it with rear axle drifting sideways just a touch ... and with traction control on. The shift only needs to be fast ... not brutal. Not a true powershift but carrying some RPM's at clutch engagement any lots of throttle as you quickly release (not pop) the clutch.
Agreed, Mine is stock also and I have been able to get a good bark that suprised me because I wasn't really in it that hard. Just practice good ,fast clean shifts.
Old Jun 26, 2007 | 08:33 PM
GT_350's Avatar
TCS off.......
Old Jun 26, 2007 | 08:52 PM
Dougxox's Avatar
I can get one with TCS on and in an auto, thanks to Doug's tune!
Old Jun 26, 2007 | 09:11 PM
Rapture's Avatar
Make sure TCS is off. Press the button anyway.
Old Jun 26, 2007 | 09:32 PM
bored out's Avatar
Bone stock, I actually pulled into traffic one day hard on 1st and shifted quick into second and the tires screamed, it was sweet.
Get first gear too about 5,500 and let the clutch out quick when second is engaged.
Old Jun 26, 2007 | 09:49 PM
05GT-O.C.D.'s Avatar
I lust for a M24
If you really want to get the hang of it but are getting a little scared by the quick shift. Slowly go up to 35-40 ish in 1st gear, gently shift into second, then push the clutch in, tack up to 4k or so, and slowly come off the clutch. As soon as you feel it start to grab, but not before, then quickly come off the clutch as you apply the accellerator. <insert nice long sqwaking sound here>
Do it in a parking lot and not on the street where your back end can come loose, scare you into drifting left of center and killing a family riding in their car.
Old Jun 26, 2007 | 10:03 PM
Bingo's Avatar
I got the Tillman Speed 93 octane race tune and I chirp 2nd with no problem...Stock 235 Pirellis.
